Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Accessible custom control
Accessible custom control [message #1062254] |
Thu, 06 June 2013 14:12 |
I'm having some trouble trying to do make a custom control accessible. I've seen examples involving a manually drawn control based on Canvas, but what I'm doing is a little bit different from that and, I had hoped, would be a little bit easier. I've just placed some labels in a composite, and I'm simulating focus over them by manually handling the relevant keyboard/mouse events, maintaining the focus state myself, and painting a focus indicator. Now I just want to enable accessibility by changing the role and state for the labels and sending the right events as the focus and selection change.
I've created a simple example to illustrate what I'm trying to do and the difficulties I'm having. It's based on an example that Carolyn MacLeod posted on platform-swt-dev back in 2004 called AccessibleShapes. Mine is called AccessibleLabels:
import org.eclipse.swt.SWT;
import org.eclipse.swt.accessibility.ACC;
import org.eclipse.swt.accessibility.AccessibleControlAdapter;
import org.eclipse.swt.accessibility.AccessibleControlEvent;
import org.eclipse.swt.events.FocusAdapter;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.MouseAdapter;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class AccessibleLabels {
static Display display;
static Shell parentShell;
static Shell shell;
static Composite composite;
static Label blueLabel;
static Label redLabel;
static Control focus;
static boolean dialog = false; // true for dialog, false for plain shell
display = new Display();
if (dialog) {
parentShell = new Shell(display);
shell = new Shell(parentShell);
} else {
shell = new Shell(display);
shell.setText(dialog ? "Dialog" : "Shell");
shell.setLayout(new FillLayout());
composite = new Composite(shell, SWT.NONE);
GridLayout gridLayout = new GridLayout();
gridLayout.marginWidth = 20;
gridLayout.marginHeight = 20;
gridLayout.verticalSpacing = 20;
gridLayout.horizontalSpacing = 20;
gridLayout.numColumns = 2;
gridLayout.makeColumnsEqualWidth = true;
composite.setLayout(gridLayout);
blueLabel = new Label(composite, SWT.CENTER);
blueLabel.setText("Blue");
blueLabel.setForeground(Display.getDefault().getSystemColor(SWT.COLOR_WHITE));
blueLabel.setBackground(Display.getDefault().getSystemColor(SWT.COLOR_BLUE));
GridData gridData = new GridData(SWT.FILL, SWT.FILL, true, true);
gridData.widthHint = 100;
gridData.heightHint = 100;
blueLabel.setLayoutData(gridData);
redLabel = new Label(composite, SWT.CENTER);
redLabel.setText("Red");
redLabel.setForeground(Display.getDefault().getSystemColor(SWT.COLOR_WHITE));
redLabel.setBackground(Display.getDefault().getSystemColor(SWT.COLOR_RED));
redLabel.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
PaintListener paintListener = new PaintListener() {
public void paintControl(PaintEvent e) {
if (e.widget == focus) {
Rectangle bounds = ((Control)e.widget).getBounds();
e.gc.drawFocus(0, 0, bounds.width, bounds.height);
blueLabel.addPaintListener(paintListener);
redLabel.addPaintListener(paintListener);
MouseListener mouseListener = new MouseAdapter() {
public void mouseDown(MouseEvent e) {
setFocus((Control)e.widget);
blueLabel.addMouseListener(mouseListener);
redLabel.addMouseListener(mouseListener);
composite.addFocusListener(new FocusAdapter() {
public void focusGained(FocusEvent e) {
updateFocus();
composite.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
switch (e.detail) {
case SWT.TRAVERSE_TAB_NEXT:
case SWT.TRAVERSE_TAB_PREVIOUS:
setFocus(focus == blueLabel ? redLabel : blueLabel);
e.doit = true;
break;
composite.getAccessible().addAccessibleControlListener(new AccessibleControlAdapter() {
public void getFocus(AccessibleControlEvent e) {
if (composite.isFocusControl()) {
if (focus == null) {
e.childID = ACC.CHILDID_SELF;
} else {
e.accessible = focus.getAccessible();
} else {
e.childID = ACC.CHILDID_NONE;
public void getSelection(AccessibleControlEvent e) {
getFocus(e);
blueLabel.getAccessible().addAccessibleControlListener(new AccessibleControlAdapter() {
public void getRole(AccessibleControlEvent e) {
if (e.childID == ACC.CHILDID_SELF) {
e.detail = ACC.ROLE_RADIOBUTTON;
public void getState(AccessibleControlEvent e) {
e.detail = ACC.STATE_FOCUSABLE | ACC.STATE_SELECTABLE;
if (composite.isFocusControl() && blueLabel == focus) {
e.detail |= ACC.STATE_FOCUSED | ACC.STATE_SELECTED | ACC.STATE_CHECKED;
redLabel.getAccessible().addAccessibleControlListener(new AccessibleControlAdapter() {
if (composite.isFocusControl() && redLabel == focus) {
shell.pack();
shell.open();
if (dialog) {
parentShell.pack();
parentShell.open();
shell.setFocus();
shell = parentShell;
composite.setFocus();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
static void setFocus(Control newFocus) {
focus = newFocus;
redraw();
updateFocus();
static void updateFocus() {
composite.getAccessible().setFocus(ACC.CHILDID_SELF);
} else {
// composite.getAccessible().setFocus(???);
static void redraw() {
composite.redraw();
blueLabel.redraw();
redLabel.redraw();
So you can see, I'm trying to rely on the Composite to know what it's children, the Labels, are and where they are and such.
Is this a reasonable thing to even try to do? I've been totally unable to find any examples of this approach, but it seems fairly natural to me.
There's just one obvious hole: I can't figure out how I can send the right focus change event. Notice the commented out line in updateFocus(). I'm not assigning child IDs myself, and I can't find a way to access whatever ID is being used internally (if there even is one). It seems to me there should be such a way, or there should be an alternative form of setFocus() that takes, perhaps, the Accessible of the focused child. Am I missing something here?
That idea comes from something analogous above. Notice how in the AccessibleControlListener for the composite, I'm setting the AccessibleControlEvent.accessible to the Accessible of the child Control that I consider focused. Is this correct? The Javadoc for AccessibleControlListener suggests it is, but again, I haven't found an example of that anywhere.
That brings me to my last problem: This doesn't work at all. If I have Insepct listening, it crashes immediately with an NPE:
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.swt.accessibility.Accessible.Skip(Accessible.java:2776)
at org.eclipse.swt.accessibility.Accessible$12.method4(Accessible.java:504)
at org.eclipse.swt.internal.ole.win32.COMObject.callback4(COMObject.java:101)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at snippets.AccessibleLabels.main(AccessibleLabels.java:185)
It's not clear to me just how the NPE relates to the code I've written, so naturally I just tried commenting stuff out. It turns out that if I don't add the AccessibleControlListener to the Composite, the problem goes away. But here's something interesting: If I still add the listener, but comment out my overrides of getFocus() and getSelection(), I still get the NPE. So, somehow just having a listener there, even if it does nothing, still causes the problem.
The Javadoc for AccessibleControlAdapter says that "classes that wish to deal with AccessibleControlEvents can extend this class and override only the methods that they are interested in," but it seems there's something I need to be overriding that I'm not. Or, perhaps, once again, my whole approach is flawed to begin with?
Any suggestions or advice would be much appreciated. I've been trying this on 32-bit SWT for Windows, from the 4.3RC3 build.
Thanks in advance,
Dave
Current Time: Sun Aug 31 23:50:53 EDT 2025
Powered by FUDForum. Page generated in 0.09285 seconds
