Home » Modeling » EMF » How to programmatically generate java code from .genmodel?
How to programmatically generate java code from .genmodel? [message #1062144] Thu, 06 June 2013 04:38 Go to next message
hi,
I generate .genmodel from .ecore from code, but I don't know to generate
java code from .genmodel from code.Do you have any idea?
[Updated on: Thu, 06 June 2013 05:00] by Moderator
Re: How to programmatically generate java code from .genmodel? [message #1062192 is a reply to message #1062144] Thu, 06 June 2013 09:23 Go to previous messageGo to next message
You mean like with Ant?
On 06/06/2013 10:38 AM, Abbas Mansoori Razi wrote:
Re: How to programmatically generate java code from .genmodel? [message #1062434 is a reply to message #1062192] Fri, 07 June 2013 12:48 Go to previous messageGo to next message
no I will use in a plugin project.
Re: How to programmatically generate java code from .genmodel? [message #1062516 is a reply to message #1062434] Sat, 08 June 2013 03:51 Go to previous message
Abbas,
You can look at how the
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModelActionBarContributor.GenerateAction
action in the Generator is implemented. Also look closely at how the
Generator loads the model, i.e.,
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModelEditor.initialize(GenModel).
Previous Topic:Generating custom made href values when saving a model
Next Topic:Generated code and PDE API Baselines
Current Time: Thu Jul 31 03:56:29 EDT 2025
Powered by FUDForum. Page generated in 0.27672 seconds
