Multi-path logic needed in test case [message #1061919] |
Tue, 04 June 2013 13:28  |
I have a test case that needs to execute one of three other test cases, conditional upon the value selected in a particular Combo component. I tried one way of accomplishing this, testing for each of the three values and executing the appropriate test case for the condition that is satisfied, but then the two conditions that are not satisfied throw errors, which causes the entire test to count as failed.
I thought I had figured out a way of fixing this, using a variable check and a Retry event handler, but then I discovered that the behavior that I was counting on (being able to modify the variable inside the event handler) was considered incorrect and patched out.
I downloaded a project (attached to the bug in question) that supposedly demonstrates a workaround, but I must not have imported it correctly because there seems to be a lot missing from it.
So, is there some relatively straightforward way to implement this kind of multi-path logic in a test case without getting errors from the paths not taken? Or do I need to resort to the above mentioned variable-check workaround (after finding out how it actually works)?
Thanks!
Re: Multi-path logic needed in test case [message #1062099 is a reply to message #1061919] |
Wed, 05 June 2013 19:42   |
I believe that I have finally figured out a way to implement this. It is not exactly straightforward, but as far as I can tell, it works, and should theoretically be extensible to any number of paths and values to be validated.
First, each value to be compared or validated must be stored in its own variable. Then, a test case should be defined for each valid value of the conditional variable, and each case should make all of its checks (starting with the conditional) using the values stored in the variables.
Then, each case after the first should be added to its preceding case as an event handler, with Event Type=Check Failed, reentry type=RETRY, and number of retries=1. This ensures that when one of the cases passes all of its checks, no more cases will be tried.
The trick is, at the end of each case after the first, you need to set EACH variable to a value that will satisfy the preceding case, in order for each previously-failed case to succeed upon retry. This way, the test will only end up failed if there is NO case that passes all of its checks.
I have attached a relatively simple but hopefully illustrative example, added to the project mentioned in the OP, and I will be happy to explain how to use it if it is not clear. It makes use of the two text fields in the SimpleAdder (the path to the jarfile must be corrected in the configuration).
I hope this proves helpful to someone!
Re: Multi-path logic needed in test case [message #1085268 is a reply to message #1083151] |
Mon, 12 August 2013 13:26  |
I was actually considering writing an extension that defines "Store Check" modules, that correspond to the Check modules but store the result in a specified variable as "true" or "false" instead of just returning it. This would make conditional logic much easier to implement as well. I just need to find the time.
FUDForum. Page generated in 0.03949 seconds
