Home » Eclipse Projects » Vex » Implementing undo/copy/cut in Vex Dialog
Implementing undo/copy/cut in Vex Dialog [message #1062069] Wed, 05 June 2013 12:41 Go to next message
When implementing a Vex dialog, similar to Florian's magazine sample, is there an easy way to add copy, undo and cut XML?
I tried:
vexWidget.addKeyListener(new KeyListener() {
  public void keyReleased(KeyEvent e) {
but it does the operations on TEXT format and not XML format (it will copy pure text, but not XML).
Putting a breakpoint in EditorManager, I noticed that when using the editor, the base contributor is VexActionBarContributor, but when using Vex inside the dialog, the base contributor is ComponentEditorContributor.
Any feedback would be appreciated.
Many thanks.
Re: Implementing undo/copy/cut in Vex Dialog [message #1062189 is a reply to message #1062069] Thu, 06 June 2013 09:06 Go to previous message
OK. Found the solution. Extended the widget and implemented the copy/paste without actually using the clipboard, but doing getSelectedFragment() in the copy and keeping the result for the paste.
Previous Topic:MathML Support
Next Topic:Reopening a dialog with Vex
Current Time: Fri Jul 25 00:02:00 EDT 2025
Powered by FUDForum. Page generated in 0.04584 seconds
