Home » Modeling » EMF » EMF's Jet templates costumization(ClassCast Exception when I add new templates to common ones)
EMF's Jet templates costumization [message #1060683] Mon, 27 May 2013 14:36 Go to next message
Hi all,
I'm trying to costumize the EMF API generation of model code by adding a new file.
I created a new project where I copied the templates from *.codegen.ecore preserving the folder's hierarchy, then I changed the templates directory in the genmodel options to the one I just copied. In order to make sure that the generation process uses these templates I added some java comments to the templates. This worked just fine.
When adding a new jet template to the template's folder, and running the generation, a java class for this template is not generated in the JETemitter project.
How can I solve this problem
Thank you in advance
Re: EMF's Jet templates costumization [message #1060761 is a reply to message #1060683] Tue, 28 May 2013 07:44 Go to previous messageGo to next message
Amine,
You have to use generator adapters for that. Try installing the
Generator Adapter Example into your workspace for an example.
On 27/05/2013 8:36 PM, Amine BEN wrote:
> Hi all,
> a new file.
> JETemitter project.
Re: EMF's Jet templates costumization [message #1062056 is a reply to message #1060761] Wed, 05 June 2013 11:13 Go to previous messageGo to next message
Hi Ed,
First thanks for your response.
I tried the validator example coming with EMF, to do so, I followed the steps to use dynamic templates.
When I run the generation using this pluging a package with the name XXX.validator is not generated.
I note that every time I run the generation i delete the .Jetemitter project and refresh the workspace.
trying this example isn't it straight forward ?
I'm a bit lost here, I appreciate your help.
Cheers
Amine
[Updated on: Wed, 05 June 2013 11:16] by Moderator
Re: EMF's Jet templates costumization [message #1062061 is a reply to message #1062056] Wed, 05 June 2013 11:26 Go to previous message
Amine,
Did you launch a runtime workspace in which that extension is installed
and then generated a model there? It doesn't work to put the example in
the workspace and they try to use it in that same workspace; the
extension must be deployed in a running IDE...
On 05/06/2013 5:13 PM, Amine BEN wrote:
> Hi Ed,
> Cheers Amine
Previous Topic:[CDO] CDOViewInvalidationEvent: can I know which CDOSession provoked it?
Next Topic:Reuse of models in a hierarchical way
Current Time: Wed Jul 30 07:08:01 EDT 2025
Powered by FUDForum. Page generated in 0.03537 seconds
