Home » Eclipse Projects » Eclipse 4 » EclipseContextFactory Inject my own classes
EclipseContextFactory Inject my own classes [message #1061535] Sun, 02 June 2013 09:57 Go to next message
i am trying to inject some of my own classes, like a Modelprovider to be reused by injection in whole of my E4 application,
At first sight, it looks simple concept, but it does not work, I read almost all the posts on this forum that talks about EclipseContextFactory but I can not implement a simple case,
in this Blog tickets from Lars Vogel http://www.vogella.com/blog/2012/02/29/eclipse-4-is-now-a-full-dependency-injection-container-with-creatable/
it describes exactly what I want to do, but i try this without sucess, I still retrieves a null object
this is a sample code of my implementation
// this is my injected class
@Creatable  @Singleton
public class SatModelProvider {
    private  List<Satellite> Satellites;
    private  List<Transponder> Transponders;
@Inject
public SatModelProvider(IEclipseContext context){
  System.out.println("the class SatModelProvider is instantiated correctly ");
here I am trying to retrieve the créated instance
public class LoadFormFileHandler {
    @Inject SatModelProvider satData;
	@Execute
	public void execute(IEclipseContext context,Shell shell) {
            System.out.println(satData.getSatellites().get(0).getName());
the retreived object satData is null,
how do I check if my class is included well in the context, and how I should proceed to retreive the existing instance.
most articles talk about using the EclipseContectFactory that I can not also implement (I've tried in the constructor with the code below)
// this is my constructor
@Inject
   ContextInjectionFactory.make(SatModelProvider.class, context);
I thank you in advance, I know the subject has been treated several times in this forum, but I was not successful implementation, if I manage to make this scenario work, I understand once the DI mechanisme in Eclipse 4.
Re: EclipseContextFactory Inject my own classes [message #1061555 is a reply to message #1061535] Sun, 02 June 2013 16:06 Go to previous messageGo to next message
I think your assumption that calling ContextInjectionFactory.make() in SatModelProvider's constructor is wrong (which shouldn't work anyways due to recursion).
You have to provide an instance of SatModelProvider OUTSIDE SatModelProvider and put it in your root IEclipseContext. You could do this in SatModelProvider's bundle activator, for example. Or you could use a model processor or a model addon.
AIT YAHIA Idir wrote on Sun, 02 June 2013 15:57
@Inject
	@Execute
@Inject
Re: EclipseContextFactory Inject my own classes [message #1061559 is a reply to message #1061555] Sun, 02 June 2013 16:57 Go to previous messageGo to next message
thanks for your response, i will check this by using an addon,as you said I have noticed the recursion, I have a loop exception.
Normally annotation @Creatable is sufficient to instantiate and put my Class in the context. My class is instantiated with the annotation (I checked with a System.out.println in the constructor), but it is not injected (i get null object with (@Inject SatModelProvider satData;)
[Updated on: Sun, 02 June 2013 16:58] by Moderator
Re: EclipseContextFactory Inject my own classes [message #1061815 is a reply to message #1061535] Tue, 04 June 2013 04:27 Go to previous messageGo to next message
Maybe my tip will help you.
I created a class:
@Creatable
public class MyClass
    private IEventBroker broker;
    @Inject
    public MyClass(IEventBroker broker)
        this.broker = broker;
    // some other methods...
Then in the same plugin in the addon I call this:
@PostConstruct
public void postConstruct(MApplication app, IEventBroker broker)
    IEclipseContext context = app.getContext();
    ContextInjectionFactory.inject(MyClass.class, context);
    context.set(MyClass.class, new MyClass(broker));
So, I get the context from main application, I inject MyClass there and then I set MyClass in the context (providing the proper argument for a constructor, which in this case could be injected in @PostConstruct).
Now whenever I inject MyClass within different plugins, it is always the same instance of MyClass (it was crucial for not to create multiple instances).
Re: EclipseContextFactory Inject my own classes [message #1061911 is a reply to message #1061815] Tue, 04 June 2013 12:30 Go to previous messageGo to next message
Mateusz,
I think you should "simplify" your code:
    MyClass myClassInstance = ContextInjectionFactory.make(MyClass.class, context);
    context.set(MyClass.class, myClassInstance);
Injecting things into MyClass.class should have no effect Smile
Mateusz Malinowski wrote on Tue, 04 June 2013 10:27
I created a class:
@Creatable
    @Inject
@PostConstruct
Re: EclipseContextFactory Inject my own classes [message #1061970 is a reply to message #1061535] Wed, 05 June 2013 03:57 Go to previous message
Erdal,
Thanks for a tip! I still would say that you need somehow provide arguments for a constructor, but in this particular case, the IEventBroker is in the application context so it can be injected.
Nevertheless, you are right and it works! Smile
Previous Topic:Integrating JDT and org.eclipse.ant in Eclipse IDE for C/C++ Developers
Next Topic:Key binding for the classic Ctrl+A on tables in native e4
Current Time: Sun Sep 21 08:36:54 EDT 2025
Powered by FUDForum. Page generated in 0.14869 seconds
