Home » Eclipse Projects » WindowBuilder » GEF Components(Default GEF components)
GEF Components [message #1061891] Tue, 04 June 2013 10:32 Go to next message
I would like to know why the WB does not use the standard classes the GEF, for example, Figure, GraphicalEditPart, EditPart ...
I would like to implement the scroll inside the EditPart (the same way that the example does LogicCircuit GEF).
I'm doing my toolkit, I can use the classes GEF standards?
thank a lot!
[]s
Rodrigo
Re: GEF Components [message #1061934 is a reply to message #1061891] Tue, 04 June 2013 17:20 Go to previous messageGo to next message
WB uses a light weight, high performance subset of GEF that is compatible across all the different Eclipse versions that we support. Using standard GEF was just not suitable for what we needed to do.
That said, I don't see any reason you couldn't extend it in much the same way you would standard GEF.
Re: GEF Components [message #1062047 is a reply to message #1061934] Wed, 05 June 2013 10:43 Go to previous message
I need to add support to scroll inside an Composite.
To do this, the GEF uses the default class Viewport, ViewportUtilities.
All of these classes, using as basis the IFigure interface, which does not exist in the version of WB.
I have to implement my lightweight version of this subset of classes, correct?
Previous Topic:WindowBuilder Project wanted
Next Topic:Cannot change inherited controls
Current Time: Sat Jul 26 17:03:18 EDT 2025
Powered by FUDForum. Page generated in 0.03114 seconds
