How to profile as "Eclipse Application" [message #106179] |
Mon, 23 July 2007 12:07  |
Originally posted by: jamesb.broadcom.com
Hi all,
I'm trying to profile the CDT debug plugins to identify hotspots in our
Launch configuration or the bits we run off.
Using a 32-bit platform, I can create a simple hello world app,
right-click Profile As->Java Application, select Execution Time analysis
and get reasonable timing output for main and other called methods. All
good so far!
However if I try to do the same thing using Profile As->Eclipse
Application (as I would to debug), there are a number of problems:
1) The Project workspace path has been mangled. i.e. instead of using
../runtimeEclipseApplication/.... (as shown in the debug as/profile as
dialog) it ends up creating directories with paths like:
/home/jamesb/"/home/jamesb/jamesb-work/.metadata/
or /home/jamesb/"file:/....
It seems that somewhere a quote ' " ' is being passed as part of the
workspace path, and a workspace is being created, with literal quotes,
relative to my home directory...
(If I simply perform a debug launch, everything works as expected.)
2) Finally, when I exit the application, nothing has been instrumented,
and in the Profile perspective, Execution Time Analysis is empty.
Obviously I haven't configured it properly (though it did "just work" for
the simple java app)...
I've had a look in the help and a google for tutorials/docs on how to
profile an Eclipse application/Eclipse plugins, and have so far drawn a
blank.
Has anyone else seen either of these problem, or can anyone point me in
the right direction for a solution?
Many thanks,
James
Re: How to profile as "Eclipse Application" [message #106449 is a reply to message #106268] |
Wed, 25 July 2007 06:22  |
Ugh!
Well it seems running my HelloWorld App (and Eclipse App) from within
Eclipse, using the External Agent works! So likely it's a Java path issue
when using the shell :s
At least there's progress :D
Is it worth filing a bug report about the IAC not working under x86_64, or
is this a known problem (It's difficult to know whether my issue has been
reported before...)
James
FUDForum. Page generated in 0.03765 seconds
