Home » Archived » Hudson » Git plugin push notification
Git plugin push notification [message #1061745] Mon, 03 June 2013 13:38 Go to next message
Are there plans to implement 'push notification' for the Hudson Git plugin?
//hudsonServer/git/notifyCommit?url=<git repository url>&branches=develop
Here is the corresponding Hudson SVN plugin capability:
wiki.hudson-ci.org/display/HUDSON/Subversion+Plugin#SubversionPlugin-Postcommithook
Here is the corresponding Jenkins Git plugin capability:
wiki.jenkins-ci.org/display/JENKINS/Git+Plugin#GitPlugin-Pushnotificationfromrepository
Thanks.
Re: Git plugin push notification [message #1061760 is a reply to message #1061745] Mon, 03 June 2013 15:36 Go to previous messageGo to next message
Obviously a good thing to have. I'll put it on my list near the top. If all goes well, in a couple of days..
Re: Git plugin push notification [message #1062745 is a reply to message #1061760] Mon, 10 June 2013 11:12 Go to previous messageGo to next message
Eric, could you please file a bug for tracking purpose. Thanks
Re: Git plugin push notification [message #1062771 is a reply to message #1062745] Mon, 10 June 2013 12:27 Go to previous messageGo to next message
No problem. https://bugs.eclipse.org/bugs/show_bug.cgi?id=410363
Re: Git plugin push notification [message #1066364 is a reply to message #1062771] Tue, 02 July 2013 06:53 Go to previous messageGo to next message
Any progress on this issue? I've noticed that Jenkins implementation does not require authentication even on the secured instance. Could it also apply to SVN plugin?
Re: Git plugin push notification [message #1225613 is a reply to message #1066364] Mon, 30 December 2013 04:43 Go to previous messageGo to next message
Since GIT is nowadays widely used this feature/bug seems urgent in my opinion. What are plans for fixing this?
Re: Git plugin push notification [message #1231607 is a reply to message #1225613] Tue, 14 January 2014 22:18 Go to previous messageGo to next message
Can you please check git plugin version 2.2.5. It is already implemented.
http://wiki.hudson-ci.org/display/HUDSON/Git+Plugin#GitPlugin-PostCommitHook
Re: Git plugin push notification [message #1232149 is a reply to message #1061745] Thu, 16 January 2014 05:06 Go to previous messageGo to next message
I'm using git plugin 2.2.5 and it need auth
$ curl http:/ /aaa/git/notifyCommit?url=https:/ /bbb/d.rzeszot/test-git-pull.git -v
> GET /git/notifyCommit?url=https:/ /bbb/d.rzeszot/test-git-pull.git HTTP/1.1
> User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
> Host: aaa
> Accept: */*
< HTTP/1.1 403 Forbidden
< Date: Thu, 16 Jan 2014 14:32:25 GMT
< Server: Apache/2.2.20 (Ubuntu)
< Set-Cookie: JSESSIONID=A0D6EB97F3A9BBBB11111D4E3A47E3; Path=/
< Vary: Accept-Encoding
< Content-Length: 563
< Content-Type: text/html;charset=UTF-8
<html><head><meta http-equiv='refresh' content='1;url=/login?from=%2Fgit%2FnotifyCommit'/><script>window.location.replace('/login?from=%2Fgit%2FnotifyCommit');</script></head><body style='background-color:white; color:white;'>Authentication required</body></html>        d
But with auth everything is ok (curl with --user "user:pass").
Perhaps this is the problem:
1) https: //git.eclipse.org/c/hudson/org.eclipse.hudson.core.git/tree/hudson-core/src/main/java/hudson/model/Hudson.java#n3751
2) UnprotectedRootAction => https: //github.com/hudson3-plugins/git-plugin/blob/master/src/main/java/hudson/plugins/git/GitStatus.java#L37
[Updated on: Thu, 16 January 2014 09:52] by Moderator
Re: Git plugin push notification [message #1232301 is a reply to message #1232149] Thu, 16 January 2014 11:29 Go to previous messageGo to next message
Thanks for the sleuthing. I will take a look at it.
Re: Git plugin push notification [message #1232380 is a reply to message #1232301] Thu, 16 January 2014 15:24 Go to previous messageGo to next message
Hmm.. I just tested. It does work for me, even with security enabled.
One issue, I see was even though I specified a specific git URL,
the polling happens on all jobs for which SCM polling is specified.
This needs a fix
wjprakash@seaview:~$ curl http://ci.hudson-ci.org/git/notifyCommit?url=https://github.com/wjprakash/hudson-test.git
Scheduled polling of core.hudson_core
Scheduled polling of core.stapler_core
Scheduled polling of core.test-harness_core
Scheduled polling of plugins.birt-chart-plugin_hr
Scheduled polling of plugins.clover-plugin_hr
Scheduled polling of plugins.cobertura-plugin_hr
Scheduled polling of plugins.collabnet-plugin_hr
Scheduled polling of plugins.console-column-plugin_hr
Scheduled polling of plugins.copyartifact-plugin_hr
Scheduled polling of plugins.crowd2-plugin_hr
Scheduled polling of plugins.cvs-plugin_hr
Scheduled polling of plugins.dashboard-view-plugin_hr
Scheduled polling of plugins.deploy-plugin_hr
Scheduled polling of plugins.disk-usage-plugin_hr
Scheduled polling of plugins.extreme-feedback-panel-plugin_hr
Scheduled polling of plugins.git-plugin_hr
Scheduled polling of plugins.groovy-support-plugin_hr
Scheduled polling of plugins.gwt-plugin_hr
Scheduled polling of plugins.jaxb-plugin_hr
Scheduled polling of plugins.jcaptcha-plugin_hr
Scheduled polling of plugins.jdepend-plugin_hr
Scheduled polling of plugins.jfreechart-plugin_hr
Scheduled polling of plugins.jna-native-plugin_hr
Scheduled polling of plugins.legacy-maven-plugin_hr
Scheduled polling of plugins.math-lib
Scheduled polling of plugins.maven-hpi-plugin_core
Scheduled polling of plugins.maven3-plugin_hr
Scheduled polling of plugins.multiline-tabbar-plugin_hr
Scheduled polling of plugins.plot-plugin_hr
Scheduled polling of plugins.rest-plugin_hr
Scheduled polling of plugins.ssh-slaves-plugin_hr
Scheduled polling of plugins.Subversion Plugin
Scheduled polling of plugins.windows-azure-storage-plugin-hr
Scheduled polling of plugins.windows-slaves-plugin_hr
Scheduled polling of Test.simple-test
[Updated on: Thu, 16 January 2014 15:25] by Moderator
Re: Git plugin push notification [message #1232587 is a reply to message #1061745] Fri, 17 January 2014 04:28 Go to previous messageGo to next message
User Anonymous has no rights. This is our user case.
Maybe that is the reason why it don't works.
Can you tak a look at it?
[Updated on: Fri, 17 January 2014 06:22] by Moderator
Re: Git plugin push notification [message #1232744 is a reply to message #1232587] Fri, 17 January 2014 11:09 Go to previous messageGo to next message
Damian, actually I tested with that scenario in mind. The authorization scheme is team management.
If you go to http://ci.hudson-ci.org and click on the "Tests" tab, you don't see any jobs (unless logged in as a user
who has authorized to view those jobs). This is because, Anonymous has no rights to read those jobs.
However, from command line I tried "push notify" one of the jobs in that team (Test.simple-test).
You can see in the above list "Scheduled polling of Test.simple-test"
Re: Git plugin push notification [message #1234100 is a reply to message #1232744] Tue, 21 January 2014 03:36 Go to previous messageGo to next message
I have Active Directory and Role-Based Strategy. Do you see any solution?
Re: Git plugin push notification [message #1250674 is a reply to message #1232380] Wed, 19 February 2014 08:26 Go to previous messageGo to next message
Has 'polling all jobs' been fixed? We need to have this as soon as possible.
[Updated on: Thu, 20 February 2014 04:49] by Moderator
icon14.gif  Re: Git plugin push notification [message #1282547 is a reply to message #1232380] Wed, 02 April 2014 09:17 Go to previous messageGo to next message
Hi, I've fixed issue with triggering polling for all jobs from onNotifyCommit when using push notification - Pull Request:
https://github.com/hudson3-plugins/git-plugin/pull/6
Re: Git plugin push notification [message #1282720 is a reply to message #1282547] Wed, 02 April 2014 14:06 Go to previous messageGo to next message
Hi Lukasz, thanks for the patch. I merged the pull request
Re: Git plugin push notification [message #1295839 is a reply to message #1282720] Mon, 14 April 2014 12:23 Go to previous messageGo to next message
Cross posting from -> http://www.eclipse.org/forums/index.php/m/1295817
Hi Lukasz,
I've been testing the new plugin and while most cases are fixed, I've found that a cascaded job with a different git URL will still be triggered if the job it cascaded from has a git URL matching the post-commit hook trigger. Winston is going to take a look and see if it's an easy fix and then we should be ready to go quite quickly after that.
Geoff
Re: Git plugin push notification [message #1297032 is a reply to message #1295839] Tue, 15 April 2014 07:19 Go to previous messageGo to next message
The git-plugin will be released later today by Winston.
Further details in this post =>
http://www.eclipse.org/forums/index.php/m/1297031/#msg_1297031
Re: Git plugin push notification [message #1298181 is a reply to message #1297032] Wed, 16 April 2014 01:10 Go to previous message
Git plugin version 2.2.6 is now available in the update center
Previous Topic:Problems : Unable to read .../hudson/hudson_home/hudson-security.xml
Next Topic:Accept pull request which adds option to ignore notifications from post-commit hooks in git-plugin
Current Time: Wed Jul 23 09:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.72886 seconds
