Home » Modeling » TMF (Xtext) » CTRL+SPCACE for Cross Reference
CTRL+SPCACE for Cross Reference [message #1061598] Mon, 03 June 2013 04:38 Go to next message
Hi all ,
When I enter ctrl +space ,all usable objects get.I want to customize this window.Which class is used for this.such as I load screenshot Contentype parent: cttype2 must not get in this .When I enter ctrl+space ,gets onlly cttype1 and then user will change cttype1.How can I do this.and Which class is used for this problem ?
Best Regards
  • Attachment: removeown.png
    (Size: 23.16KB, Downloaded 136 times)
Re: CTRL+SPCACE for Cross Reference [message #1061602 is a reply to message #1061598] Mon, 03 June 2013 04:52 Go to previous messageGo to next message
The class is youdslproposalprovider. It calls look up cross
reference. This allows a filter predicate
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: CTRL+SPCACE for Cross Reference [message #1061612 is a reply to message #1061602] Mon, 03 June 2013 05:46 Go to previous messageGo to next message
Hi Christian
Thank you
best regards.
Re: CTRL+SPCACE for Cross Reference [message #1061713 is a reply to message #1061612] Mon, 03 June 2013 11:01 Go to previous messageGo to next message
Hi Christian ,
I write java code (util class) with filter predicate.I want to use it .AbstractContentProposalProvider class is Xtend class.I want to call below code in this class.
public static ArrayList<ContentType> getPossibleParentContentType(ContentType content){
		Web web = ((Web)((CustomList)content.eContainer()).eContainer());
		while(web.eContainer().eClass().getName().equals("Web")){
			web = (Web) web.eContainer();
		ArrayList<ContentType> allContentTypes = new ArrayList<>();
		allContentTypes = returnAllContentTypeFromGivenWeb(web, allContentTypes);
		allContentTypes.remove(content);
		return allContentTypes;
Re: CTRL+SPCACE for Cross Reference [message #1061714 is a reply to message #1061612] Mon, 03 June 2013 11:01 Go to previous messageGo to next message
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061715 is a reply to message #1061612] Mon, 03 June 2013 11:02 Go to previous messageGo to next message
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061717 is a reply to message #1061612] Mon, 03 June 2013 11:02 Go to previous messageGo to next message
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061718 is a reply to message #1061602] Mon, 03 June 2013 11:03 Go to previous messageGo to next message
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061719 is a reply to message #1061602] Mon, 03 June 2013 11:03 Go to previous messageGo to next message
Hi Christian ,
Christian Dietrich wrote on Mon, 03 June 2013 04:52
Re: CTRL+SPCACE for Cross Reference [message #1061720 is a reply to message #1061602] Mon, 03 June 2013 11:05 Go to previous messageGo to next message
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061727 is a reply to message #1061720] Mon, 03 June 2013 11:32 Go to previous messageGo to next message
Sorry this looks you want to customize scoping and not only the
proposals. As always I find it difficult to get your point.
Re: CTRL+SPCACE for Cross Reference [message #1061794 is a reply to message #1061727] Tue, 04 June 2013 02:01 Go to previous messageGo to next message
Hi Christian,
I examine related examples.but There are a lot of class.do you recommended which class?
I must I use AbstractContentProposalProvider ? or can I use ImportedNamespaceAwareLocalScopeProvider or AbstractDeclarativeScopeProvider?
Hence can I use my util class for this problem ?
Re: CTRL+SPCACE for Cross Reference [message #1061795 is a reply to message #1061794] Tue, 04 June 2013 02:16 Go to previous messageGo to next message
Please Post a simple example with a hello world grammar with what you want to achive.
There are Tons of scoping Exemples in this forum that might help
And id use the scopeprovider class that is already there or Even
Do this with a Check and Not adopt scoping or proposalprovider at all
Re: CTRL+SPCACE for Cross Reference [message #1061807 is a reply to message #1061720] Tue, 04 June 2013 03:51 Go to previous messageGo to next message
Hi Christian,
I want to use below code because,I sycn GMF and XTEXT.so I wrote util class for use GMF and XTEXT.so I want to use this code for not to do the same procedures
the second time.How can I call my ready code (util class)?
junior developer wrote on Mon, 03 June 2013 11:05
Hi Christian ,
Re: CTRL+SPCACE for Cross Reference [message #1061808 is a reply to message #1061807] Tue, 04 June 2013 03:53 Go to previous messageGo to next message
Adapt scoping
Re: CTRL+SPCACE for Cross Reference [message #1061810 is a reply to message #1061808] Tue, 04 June 2013 04:07 Go to previous messageGo to next message
Hi ,
AbstractDeclarativeScopeProvider is Xtend class.can I use AbstractDeclarativeScopeProvider?
Re: CTRL+SPCACE for Cross Reference [message #1061811 is a reply to message #1061810] Tue, 04 June 2013 04:09 Go to previous messageGo to next message
I said: There is already a (empty) scope provider generated by default. use that one.
Re: CTRL+SPCACE for Cross Reference [message #1061820 is a reply to message #1061811] Tue, 04 June 2013 04:53 Go to previous messageGo to next message
Hi ,
I will try .
but I ask one question :
I can Adapt scoping .I examine this example http://20000frames.blogspot.com/2010/09/extending-models-in-xtext-projects.html
If I can understand adapt scoping correctly ,can I use my util class with this way?
Re: CTRL+SPCACE for Cross Reference [message #1061821 is a reply to message #1061820] Tue, 04 June 2013 05:00 Go to previous message
One thing after another. Don't know what this has todo with scoping
Previous Topic:Errors after upgrading from Xtext 2.3 to 2.4
Next Topic:Using XCore Model for XText DSL
Current Time: Wed Jul 23 17:01:28 EDT 2025
Powered by FUDForum. Page generated in 0.06207 seconds
