Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] NullPointer while generating ORM Annotated Model
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061670 is a reply to message #1061642] |
Mon, 03 June 2013 08:35   |
Hi Bastian,
And I need to say sorry again :-(, I found that to, in the meantime I have done another build which should really solve
this, I published it 5 mins ago, this latest build hopefully helps...
gr. Martin
On 06/03/2013 01:43 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> I'm sorry, but this had no effect. I just installed the new version, deleted all older plugins, restarted Eclipse, but
> still get the following message:
> !ENTRY org.eclipse.ui 4 0 2013-06-03 13:40:25.680
> !MESSAGE Unhandled event loop exception
> !STACK 0
> java.lang.IllegalStateException: java.lang.reflect.InvocationTargetException
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:86)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
> at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
> at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:601)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
> Caused by: java.lang.reflect.InvocationTargetException
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
> at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
> at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
> at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
> at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:79)
> ... 29 more
> Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NullPointerException
> at
> org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:106)
> at
> org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFiles(GenerateAnnotationModel.java:48)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:127)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:107)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:75)
> at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
> at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
> at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
> Caused by: java.lang.IllegalStateException: java.lang.NullPointerException
> at
> org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:98)
> at
> org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:104)
> ... 8 more
> Caused by: java.lang.NullPointerException
> at java.io.File.<init>(File.java:251)
> at
> org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:70)
> ... 9 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061737 is a reply to message #1061677] |
Mon, 03 June 2013 12:37   |
Hi Bastian,
With me it works fine, so it must be something specific to your dev project which I am missing.
Can you email me your dev project?
gr. Martin
On 06/03/2013 03:14 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> it seems, I cannot generate ORM-files, too. I'll post the stack trace which looks different. Maybe this could help.
> !ENTRY org.eclipse.ui 4 0 2013-06-03 15:13:17.143
> !STACK 0
> ... 29 more
> at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFile(ORMGenerator.java:195)
> at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFiles(ORMGenerator.java:177)
> at org.eclipse.emf.texo.orm.annotator.ORMGenerator.storeORM(ORMGenerator.java:221)
> at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateStoreORM(ORMGenerator.java:211)
> at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFile(ORMGenerator.java:193)
> ... 8 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1070671 is a reply to message #1070569] |
Thu, 18 July 2013 08:35   |
Hi Roland,
Thanks for sharing (this one has bugged me for a while...), looking again at the code I think it should be changed. Can
you try/test the attached diff? Does it help?
Thanks again Roland!
gr. Martin
On 07/18/2013 10:30 AM, R. Oldenburg wrote:
> Hi all,
> just had the same issue.
> I could resolve it quick-and-dirty with the following change in AnnotationModelGenerator:
> line 70:
> - final URI fileUri = URI.createURI(modelFile.getParent().getLocation().toOSString());
> - final File file = new File(AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri, suffix)
> - .toFileString());
> + final URI fileUri = URI.createFileURI(modelFile.getLocation().toOSString());
> + final File file = new File(fileUri.toString()).getParentFile();
> Regards,
> Roland
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1074136 is a reply to message #1073658] |
Fri, 26 July 2013 03:17   |
Hi Martin,
I tried the new release but the generation ORM file does not work.
!ENTRY org.eclipse.ui 4 0 2013-07-26 08:52:05.943
!STACK 0
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
... 30 more
Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore epackage adbk epackage uri : platform:/resource/com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:107)
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFiles(GenerateAnnotationModel.java:48)
Caused by: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore epackage adbk epackage uri : platform:/resource/com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore
at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:93)
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:104)
... 8 more
at org.eclipse.emf.texo.annotations.AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(AnnotationModelSuffixHandler.java:48)
at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:68)
... 9 more
Looking at the code, the problem should be here:
public void createStoreAnnotationModel(EPackage ePackage, String suffix, EPackage annotationEPackage, IFile modelFile) {
try {
final ResourceSet resourceSet = ePackage.eResource().getResourceSet();
final URI fileUri = URI.createURI(modelFile.getLocation().toOSString());
final File file = new File(AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri, suffix).toFileString());
final Resource resource;
if (file.exists()) {
resource = resourceSet.getResource(fileUri, true);
} else {
resource = resourceSet.createResource(fileUri);
final String encoding = ((XMLResource) ePackage.eResource()).getEncoding();
((XMLResource) resource).setEncoding(encoding);
I have corrected the code in this way:
public void createStoreAnnotationModel(EPackage ePackage,String suffix, EPackage annotationEPackage,IFile modelFile) {
// TODO Auto-generated method stub
try {
final org.eclipse.emf.common.util.URI fileUri = org.eclipse.emf.common.util.URI.createFileURI(modelFile.getLocation().toOSString()); //change
final org.eclipse.emf.common.util.URI fileOrmUri = AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri,suffix);//change
final File file = new File(fileOrmUri.toFileString());//change
} else {
resource = resourceSet.createResource(fileOrmUri);//change
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1074392 is a reply to message #1074136] |
Fri, 26 July 2013 12:35   |
Hi Gabriele, Thorben,
I published a new build which should hopefully solve this problem...
Can you retry?
gr. Martin
On 07/26/2013 09:17 AM, gabriele boldrin wrote:
> Hi Martin,
> !STACK 0
> ... 30 more
> at
> at
> at
> at
> ... 8 more
> at
> at
> ... 9 more
> try {
> } else {
> @Override
> try {
> } else {
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1075382 is a reply to message #1075373] |
Mon, 29 July 2013 06:32  |
:-) Yes I was about to ping you on this version, I made the last change you proposed.
Thanks for your patience in this, good to hear that it works now :-)
gr. Martin
On 07/29/2013 12:13 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> you just uploaded a new version, right?! So in this version everything's working fine :)
> Thank you a lot!
> Bastian
The Netherlands
Current Time: Sun Sep 21 00:23:14 EDT 2025
Powered by FUDForum. Page generated in 0.06011 seconds
