Home » Modeling » ATL » XML Schema (XSD) generation
XML Schema (XSD) generation [message #1061358] Fri, 31 May 2013 06:22 Go to next message
I've spent a good amount of time looking for some answers but got lost in all those Eclipse modelling technologies.
My ultimate goal is to transform an UML class model into an XSD. Transformation rules are very specific to my environment. I am wondering what is the best approach? I think about two options.
1. UML Model -> Model conforming to XSD metamodel -> XSD (text)
2. UML Model -> "Generic" ecore model -> XSD (text)
In case of 1) - how to export model conforming to XSD metamodel to the actual XSD?
In case of 2) - is it possible to customize a way how ecore to XSD is mapped (for example I would like EClass attributes not to be XSD attrbutes but elements of a complex type).
Michal
Re: XML Schema (XSD) generation [message #1061556 is a reply to message #1061358] Sun, 02 June 2013 16:19 Go to previous message
Op 31-05-13 21:31, Michal Kleczek schreef:
This will not work, because the XSD metamodel needs "hacks" for it to work:
http://www.eclipse.org/forums/index.php?t=msg&th=443250/
ATL needs to do what's listed here:
http://grepcode.com/file/repository.grepcode.com/java/eclipse.org/3.5/org.eclipse/xsd/2.5.0/org/eclipse/xsd/ecore/EcoreSchemaBuilder.java#EcoreSchemaBuilder.buildSchema%28org.eclipse.emf.ecore.EPackage%29
The following code:
-- @atlcompiler emftvm
-- @nsURI ECORE=http://www.eclipse.org/emf/2002/Ecore
-- @nsURI XSD=http://www.eclipse.org/xsd/2002/XSD
module EcoreToXSD;
create OUT : XSD from IN : ECORE;
rule EPackageToSchema {
from s : ECORE!EPackage
to t : XSD!XSDSchema (
targetNamespace <- s.nsURI
-- contents <- s.eClassifiers->select(c | c.oclIsKindOf(ECORE!EClass))
do {
t.setSchemaForSchemaQNamePrefix('xsd');
t.getQNamePrefixToNamespaceMap().put('xsd', 'http://www.w3.org/2001/XMLSchema');
rule EClassToComplexTypeDef {
from s : ECORE!EClass
to t : XSD!XSDComplexTypeDefinition (
name <- s.name)
gives:
org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.IllegalAccessException:
Class org.eclipse.m2m.atl.emftvm.util.EMFTVMUtil can not access a member of
class org.eclipse.xsd.impl.XSDSchemaImpl$1 with modifiers "public volatile"
at public java.lang.Object
org.eclipse.xsd.impl.XSDSchemaImpl$1.put(java.lang.Object,java.lang.Object)
Local variables: []
at rule
EPackageToSchema@postApply#8(platform:/resource//org.eclipse.m2m.atl.emftvm.tests/test-data/EcoreToXSD.atl#[16:3-16:82])
Local variables: [__trace__: TRACE!TraceLink = 48c8175f:TRACE!TraceLink, s:
ECORE!EPackage = My:ECORE!EPackage, t: XSD!XSDSchema = 5ca65965:XSD!XSDSchema]
at static EMFTVM!ExecEnv::main() :
Object(platform:/resource//org.eclipse.m2m.atl.emftvm.tests/test-data/EcoreToXSD.atl)
Local variables: []
Apparently, xpand has managed those hacks, though:
https://github.com/eclipse/xpand/blob/master/examples/org.eclipse.xpand.examples.xsd.m2m.ecore2xsd/src/xsd/m2m/ecore2xsd/ecore2xsd.ext
> XSD?
UML Model -> Ecore Model is possible in ATL.
Ecore Model -> XSD customisation can be done by creating a new "Ecore To XML
Mapping" file. I don't know the details.
> Michal
Dennis
Previous Topic:call a text file
Next Topic:Use a new instance from a rule in another rule
Current Time: Wed Jul 23 11:54:10 EDT 2025
Powered by FUDForum. Page generated in 0.25043 seconds
