Home » Eclipse Projects » NatTable » Multi-cell editing changes between 0.9.0 and 1.0.0
Multi-cell editing changes between 0.9.0 and 1.0.0 [message #1061456] Fri, 31 May 2013 13:55 Go to next message
I'm working on converting from 0.9.0 to 1.0.0. The following patch of code uses API that no longer exists:
MultiCellEditDialog dialog =
                new MultiCellEditDialog(parent.getShell(), cellEditor, originalCanonicalValue,
                                initialEditValue, allowIncrementDecrement, configRegistry,
                                lastSelectedCell);
int returnValue = dialog.open();
ActiveCellEditor.close();
if (returnValue == Window.OK) {
    try {
        Object editorValue = dialog.getEditorValue();
MultiCellEditDialog no longer exists, though it appears that CellEditDialog has support for multi-cell editing. ActiveCellEditor no longer exists. Finally, CellEditDialog doesn't have getEditorValue(), though I do see a getCommittedValue().
Does anyone have any insight or examples for how to use the new API for multi-cell editing?
Thanks.
Re: Multi-cell editing changes between 0.9.0 and 1.0.0 [message #1061459 is a reply to message #1061456] Fri, 31 May 2013 14:12 Go to previous messageGo to next message
Well the question is more, what are you trying to achieve?
Every change related to edit refactoring is collected in a forum topic that is also linked in the new & noteworthy.
In short, yes the CellEditDialog replaces the MultiCellEditDialog. It can be used for single and multi cell editing. Yes the API is generalized to support creation of new cell editors in a dialog. The API should be well documented to get an idea it.
If you tell me what you want to do, maybe I can give you a hint.
Greez,
Dirk
Re: Multi-cell editing changes between 0.9.0 and 1.0.0 [message #1061464 is a reply to message #1061459] Fri, 31 May 2013 15:06 Go to previous message
Thanks, I found that forum topic linked from the new and noteworthy shortly after I posted. I'm looking through it.
Previous Topic:Applying CSS to NatTable
Next Topic:Dependency on org.apache.commons.codec?
Current Time: Fri Sep 26 22:32:43 EDT 2025
Powered by FUDForum. Page generated in 0.05188 seconds
