Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Convert to EMF
Convert to EMF [message #1061302] Fri, 31 May 2013 02:01 Go to next message
i've been digging around to resolve my current problems in my app.
so i found http://wiki.eclipse.org/Texo/Convert_to_EMF
i got one short question to this article.
do i need to generate a TEXO model AND an EMF model
(means generating files throuch TEXO and EMF.genmodel)
thanks in advance
if so, no mapping is needed, the converter simply knows which classes to use?
Re: Convert to EMF [message #1061303 is a reply to message #1061302] Fri, 31 May 2013 02:04 Go to previous messageGo to next message
Hi Ludwig,
The Texo classes are needed. If there are no generated EMF classes then Texo will convert to DynamicEObjects. So Texo
uses the EFactory of the EPackage to instantiate the EObjects.
gr. Martin
> thanks in advance
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Convert to EMF [message #1061306 is a reply to message #1061303] Fri, 31 May 2013 02:21 Go to previous messageGo to next message
but i CAN generate the same model with a genfile, and then it recognizes these files? (if so how do i tell the location?)
Re: Convert to EMF [message #1061406 is a reply to message #1061306] Fri, 31 May 2013 09:39 Go to previous message
Yes you can, you need to make sure that the epackage of the EMF generated code is initialized before the model package
of Texo. Afair then the EMF EPackage is used by texo and the right EObjects are created.
gr. Martin
The Netherlands
Previous Topic:[Texo] OptimisticLockException
Next Topic:[Edapt] install on Kepler
Current Time: Sat Jul 26 11:29:28 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
