Home » Eclipse Projects » EclipseLink » Modify schema using persistence layer
Modify schema using persistence layer [message #1061155] Thu, 30 May 2013 05:30 Go to next message
i wonder if there is a way to modify a table schema using the eclipse link api.
For instance XYZEntity:
Property address : String was changed to deliveryAddress : String.
For normal i would have to prepare DDL-Statements for each used Database. (ALTER TABLE XYZ change ....)
But i want to avoid writing DDLs in database specific SQL-Language.
Is there a way to tell eclipse-link api to do that for me?
Thanks a lot
Florian
Re: Modify schema using persistence layer [message #1061265 is a reply to message #1061155] Thu, 30 May 2013 17:06 Go to previous messageGo to next message
Liquibase is a good tool for maintaining database independent migration scripts.
Personally I prefer treating databases a first class citizens, and not rely on Eclipselink to modify tables.
Tom
On 2013-05-30 11:30, Florian Pirchner wrote:
> Thanks a lot
> Florian
Re: Modify schema using persistence layer [message #1061313 is a reply to message #1061265] Fri, 31 May 2013 03:53 Go to previous message
Thanks a lot. Will try liquibase
Previous Topic:Model-Evolution best practices
Next Topic:Unidirectional OneToMany Insert
Current Time: Sat Jul 26 11:26:54 EDT 2025
Powered by FUDForum. Page generated in 0.06044 seconds
