No Applicable Items on File | New [message #1061095] |
Wed, 29 May 2013 17:24  |
This is a new installation of Eclipse Modeling Tools, Version: Juno Release
Build id: 20120620-1657. After installation on Win8(64-bit), I ran the Install Modeling Components from the Help menu. I selected the Papyrus component and the install seem to proceed without a problem. When i try to create a new project using File | New, there are no options available ("No Applicable Items" value in the submenu. When i select Help | Install New Software using the Papyrus - http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/juno URL, there are a list of files that will be installed under the Papyrus category including:
Papyrus Extra Binaries and Sources (Incubation) 0.9.2.v201302131017
Papyrus Extra Feature (Incubation) 0.9.2.v201302131017
Papyrus SDK Binaries (Incubation) 0.9.2.v201302131112
Papyrus SDK Binaries and sources (Incubation) 0.9.2.v201302131112
When I try to install these, I get the following error message.
Your original request has been modified.
"Papyrus SDK Binaries (Incubation)" will be ignored because it is already installed.
Cannot complete the install because one or more required items could not be found.
Software being installed: Papyrus Extra Binaries and Sources (Incubation) 0.9.2.v201302131017 (org.eclipse.papyrus.extra.sources.feature.feature.group 0.9.2.v201302131017)
Missing requirement: UML Compare Models (Incubation) 0.9.2.v201302131017 (org.eclipse.papyrus.uml.compare.subelement 0.9.2.v201302131017) requires 'bundle org.eclipse.emf.compare.uml2 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Papyrus Extra Feature (Incubation) 0.9.2.v201302131017 (org.eclipse.papyrus.extra.feature.feature.group 0.9.2.v201302131017)
To: org.eclipse.papyrus.extra.uml.compare.feature.feature.group [0.9.2.v201302131017]
From: Papyrus Extra Binaries and Sources (Incubation) 0.9.2.v201302131017 (org.eclipse.papyrus.extra.sources.feature.feature.group 0.9.2.v201302131017)
To: org.eclipse.papyrus.extra.feature.feature.group [0.9.2.v201302131017]
From: Papyrus UML Compare Feature (Incubation) 0.9.2.v201302131017 (org.eclipse.papyrus.extra.uml.compare.feature.feature.group 0.9.2.v201302131017)
To: org.eclipse.papyrus.uml.compare.subelement [0.9.2.v201302131017]
What am i missing?
[Updated on: Wed, 29 May 2013 17:28] by Moderator
FUDForum. Page generated in 0.04603 seconds
