Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ExpandItem header height?
ExpandItem header height? [message #557519] Tue, 07 September 2010 19:05 Go to next message
Hi all,
I'm sure this is quite the newbie question, but is there an easy way to change an ExpandItem's header height? I see that there is a getHeaderHeight() method, but no setter. Can the height be adjusted somehow by using layouts?
Thanks!
Jim
Re: ExpandItem header height? [message #557832 is a reply to message #557519] Thu, 09 September 2010 03:01 Go to previous messageGo to next message
The height of the ExpandItem's header is automatically computed and adjusted based on the font size, image size and chevron size, so that the text and image are properly displayed. So, you don't need to set the size of the header. Why do you want to change the header size?
Re: ExpandItem header height? [message #1061093 is a reply to message #557832] Wed, 29 May 2013 17:08 Go to previous message
Hi, when I'm change the size of the font or set image, heigth in header computed. But expandbar control does not fall (see pictures).
My code is:
FormToolkit toolkit = new FormToolkit(parent.getDisplay());
ScrolledForm form = toolkit.createScrolledForm(parent);
form.setText("Реестр оказанных услуг");
setStyleForScrolledForm(form);
final Composite container = form.getBody();
container.setLayout(new FormLayout());
final ExpandBar expBarFilters = new ExpandBar(container, SWT.V_SCROLL);
final FormData fdExpBarFilters = new FormData();
fdExpBarFilters.top = new FormAttachment(0, 0);
fdExpBarFilters.left = new FormAttachment(0, 10);
fdExpBarFilters.right = new FormAttachment(100, -10);
expBarFilters.setLayoutData(fdExpBarFilters);
expBarFilters.setData(RWT.CUSTOM_VARIANT,"Seach");
Composite expBarComposite = new Composite (expBarFilters, SWT.NONE);
final FormData fdExpBarComposite = new FormData();
fdExpBarComposite.top = new FormAttachment(0, 0);
fdExpBarComposite.left = new FormAttachment(0, 0);
fdExpBarComposite.right = new FormAttachment(100, 0);
expBarComposite.setLayout(new FormLayout());
expBarComposite.setLayoutData(fdExpBarComposite);
expBarComposite.setData(RWT.CUSTOM_VARIANT,"Seach");
ExpandItem expItemFilters = new ExpandItem(expBarFilters, SWT.NONE, 0);
expItemFilters.setText("Filters");
expItemFilters.setControl(expBarComposite);
expItemFilters.setData(RWT.CUSTOM_VARIANT,"Seach");
expItemFilters.setExpanded(true);
expBarFilters.addExpandListener(new ExpandListener() {
private static final long serialVersionUID = -7185326081415952521L;
public void itemExpanded(ExpandEvent arg0) {
expBarFilters.layout(true);
container.layout(true);
public void itemCollapsed(ExpandEvent arg0) {
Label lblProfile = BaseWidgets.createLabel(expBarComposite, "Profile", SWT.NONE, null, 12, null, 10);
etc...
expItemFilters.setHeight(expBarComposite.computeSize(SWT.DEFAULT, SWT.DEFAULT).y + 10);
Please, Help.
Thanks.
  • Attachment: pict.jpg
    (Size: 34.79KB, Downloaded 259 times)
Previous Topic:How to detect that code is running in Development environment or in generic Eclipse using Plugins?
Next Topic:[GTK-Linux] All context disappeared when open embedded view
Current Time: Thu Jul 24 22:34:39 EDT 2025
Powered by FUDForum. Page generated in 0.05214 seconds
