Home » Modeling » TMF (Xtext) » implicit variable declaration in dsl editor with xbase
implicit variable declaration in dsl editor with xbase [message #1060462] Fri, 24 May 2013 16:14 Go to next message
Hi , this is a part of my dsl grammar :
ReceiveMessage returns xbase::XExpression :
  {ReceiveMessage} 'receive message' name=ValidID 'do' body= XBlockExpression
Message returns xbase::XExpression:
	SendMessage | ReceiveMessage
XExpressionInsideBlock returns xbase::XExpression:
	XVariableDeclaration | XExpression | Message;
In my dsl editor i can write this :
behaviour HelloBehaviour is CyclicBehaviour
{ receive message msg
  do {
	val i = 5
        msg.getContent() // error no declaration of msg
I can't write msg.getContent() in the receive message body because i haven't declare msg.
I would like to write "receive message msg" in dsl editor and can use msg like a variable in the body of receive message.
(e.g implicit declaration : ACLMessage msg )
How can i do it?
Thank you...
[Updated on: Sat, 25 May 2013 19:06] by Moderator
Re: implicit variable declaration in dsl editor with xbase [message #1060528 is a reply to message #1060462] Sun, 26 May 2013 05:02 Go to previous messageGo to next message
> ReceiveMessage returns xbase::XExpression : {ReceiveMessage} 'receive
> Message returns xbase::XExpression: SendMessage | ReceiveMessage
> behaviour HelloBehaviour is CyclicBehaviour { receive message msg do {
> val i = 5
> msg.getContent() // error no declaration of msg }
> I would like can write "receive message msg" in dsl editor and can use
you should write the JvmModelInferrer accordingly, e.g., for receive
message (by the way, do not use terminal symbols with spaces: 'receive'
'message', instead of 'receive message') you can infer a method with
parameter 'msg' and with the appropriate type, and the the XExpression
after 'do' can access msg (once you associated the XExpression to the
body of the inferred method).
HOME: http://www.lorenzobettini.it
Re: implicit variable declaration in dsl editor with xbase [message #1060598 is a reply to message #1060528] Mon, 27 May 2013 04:55 Go to previous messageGo to next message
Thank you for your advices...
I don't use JvmModelInferrer for receive message but extend XBaseCompiler
This is a part of my class that extend XbaseCompiler :
override protected doInternalToJavaStatement(XExpression expr, ITreeAppendable it, boolean isReferenced) {
switch expr {
ReceiveMessage : {
			if (expr.filter != null){
				newLine
		    	append ('''MessageTemplate mt = null; ''')
  				newLine
  				append ('''mt = ''' )
  				append('''«createTemplate(expr.filter as Expression,it)» ;''')
				newLine
				append('''
					jade.lang.acl.ACLMessage msg = myAgent.receive(mt); ''')
			else {  newLine append('''jade.lang.acl.ACLMessage msg = myAgent.receive()''')}
			newLine
			append('''if (msg!=null){ ''')
			increaseIndentation()
			doInternalToJavaStatement(expr.body, it, isReferenced)
			append('''} ''')
			decreaseIndentation()
			newLine
			append('''else { block(); }''')
I call doInternalToJavaStatement method and pass ReceiveMessage body.
How i can set implicit variable declaration here?
thank you in advance
[Updated on: Mon, 27 May 2013 04:59] by Moderator
Re: implicit variable declaration in dsl editor with xbase [message #1060628 is a reply to message #1060598] Mon, 27 May 2013 07:31 Go to previous messageGo to next message
Try to use JvmModelInferrer whenever possible since you'll get for free
correct scoping!
You can have a customized XbaseCompiler to deal with your custom
XExpression (if you have any) or invoke XbaseCompiler directly if you
want to generate code before and after the actual XExpression's
translation... but for the rest, try to use JvmModelInferrer
I don't know whether this http://www.rcp-vision.com/?p=4089 might help you
Lore
On 05/27/2013 10:55 AM, andrea rossi wrote:
> Thank you for you advices...
> switch expr {
> ReceiveMessage : {
> newLine
> newLine append ('''mt = ''' )
> newLine append('''
> newLine append('''if (msg!=null){ ''')
> append('''} ''') decreaseIndentation()
> newLine append('''else { block(); }''')
> How can set implicit variable declaration here?
Re: implicit variable declaration in dsl editor with xbase [message #1061091 is a reply to message #1060628] Wed, 29 May 2013 17:06 Go to previous messageGo to next message
Thank you ,
I read the link but i can't solve my problem..
ReceiveMessage is a xbase Expression and i need to extend XbaseCompiler to manage it.
is There another way to solve this problem?any suggestions?
[Updated on: Wed, 29 May 2013 17:19] by Moderator
Re: implicit variable declaration in dsl editor with xbase [message #1061096 is a reply to message #1061091] Wed, 29 May 2013 17:36 Go to previous messageGo to next message
Hi what about Fixing the scoping Manually
Re: implicit variable declaration in dsl editor with xbase [message #1061133 is a reply to message #1061091] Thu, 30 May 2013 03:41 Go to previous messageGo to next message
On 05/29/2013 11:06 PM, andrea rossi wrote:
> Thank you ,
> to manage it.
You actually need to extend XbaseCompiler to deal with your custom
XExpression (i.e., ReceiveMessage); what I'm saying is that if you map
that concept to a Java model method and the 'msg' to a parameter then
the body, when associated to the mapped method, will automatically get a
working scope...
cheers
Lorenzo
Re: implicit variable declaration in dsl editor with xbase [message #1061485 is a reply to message #1061133] Fri, 31 May 2013 17:22 Go to previous messageGo to next message
this i part of my JvmModelInferrer :
def dispatch void infer(Model element,
                IJvmDeclaredTypeAcceptor acceptor,
                boolean isPrelinkingPhase) {
    for (a : element.elements) {
    	switch a {
    		AbstractBehaviour : {
    			switch a {
    				SimpleBehaviour : {
    					  acceptor.accept(a.toClass(a.fullyQualifiedName)).initializeLater [
    						superTypes += a.newTypeRef('jade.core.behaviours.'+ a.typeSB.toString)
    						members += a.toConstructor[
    							documentation = '''...'''
    							parameters += toParameter("agent", newTypeRef(a, 'jade.core.Agent'))
    							body = [
      									append('''
        								super(agent);
    						members += a.toMethod("action",a.newTypeRef(Void::TYPE))[
    						body = a.body
i translate each simpleBehaviour in a java class e i inferr one method(action).
The body of this method is body of behaviour(i.e XblockExpression) and it can contain xbase expression or my custom xbase expression.
How can i map ReceviMessage in the right way?(it must been contained in the action body)
any little example?
Hi Christian how can i fix the scoping of my custom xbase expression?
thank you
Re: implicit variable declaration in dsl editor with xbase [message #1061489 is a reply to message #1061485] Fri, 31 May 2013 18:55 Go to previous messageGo to next message
Sorry you have to digg into scoping yourself
Re: implicit variable declaration in dsl editor with xbase [message #1061499 is a reply to message #1061485] Sat, 01 June 2013 03:40 Go to previous message
I would map it as follows
ReceiveMessage -> Java method
name -> Java method's parameter (you have to give it a type)
body -> Java method's body
this way
val i = 5
msg can be automatically accessed...
of course I do not know all the details and semantics of your language,
so mine's just a guess...
Lorenzo
On 05/31/2013 11:22 PM, andrea rossi wrote:
> IJvmDeclaredTypeAcceptor acceptor, boolean
> switch a {
> switch a {
> SimpleBehaviour : {
> superTypes +=
> body = [
> append('''
> super(agent);
> members +=
> body = a.body
> method(action).
> the action body)
> any little example?
> thank you
Previous Topic:Nested comments
Next Topic:Problem with unresolved classpath proxy URIs after upgrading to 2.4.2
Current Time: Thu Jul 24 15:48:16 EDT 2025
Powered by FUDForum. Page generated in 0.05752 seconds
