Home » Modeling » EMF » Using eKey(How to use eKey)
Using eKey [message #1061077] Wed, 29 May 2013 16:01 Go to next message
My reading from the forum that when I use 1 field as "EKey", the EReference will have the format of /@a[name='foo'] instead of /@a.<index> in the serialized file (in my case XMI). However, I have no success at all (still always get /@a.<index>). Is there any example or document that I can refer to? Or is there any area that I should pay attention (like some options)?
Thanks very much.
Edmund
Re: Using eKey [message #1061128 is a reply to message #1061077] Thu, 30 May 2013 03:28 Go to previous message
Edmund,
Comments below.
On 29/05/2013 10:39 PM, Edmund Leung wrote:
Probably you've tried setting this on the cross reference to that type
of object but you need to set it on the containment reference that
contains that type of object. I.e., you'd need to set the eKeys for
containment reference "a" to be the attribute for "name".
> Thanks very much.
> Edmund
Previous Topic:Can trigger a method call for an attribute change in an EMF model?
Next Topic:EMF based RAP Editor
Current Time: Thu Jul 31 03:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.05535 seconds
