Home » Eclipse Projects » Remote Application Platform (RAP) » ApplicationConfiguration DS example(configure method never executed when running as a component.)
ApplicationConfiguration DS example [message #1060972] Wed, 29 May 2013 07:29 Go to next message
First of all, my apologies for all the spam here. I am really trying to figure out things on my own first, but every now and again you hit this wall that is just too high.
One the last steps I am working on is dropping the Activator, and creating a DS component for my service. That seems straightforward if you read the documentation. However, for some reason, most likely because I doing something wrong, it doesn't work.
I have implemented my definition similar to the sample definition below but the configure method is never called.
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0">
  <implementation class="com.example.SimpleConfiguration"/>
  <service>
     <provide interface="org.eclipse.rwt.application.ApplicationConfiguration"/>
  </service>
  <property name="contextName" type="String" value="example"/>
</scr:component>
When I add activator and deactivator method, they are hit when I define them in the component. This indicates to me that the DS bundle is doing it's work. The configure() method is never called though.
  <implementation class="com.example.SimpleConfiguration enabled="true" immediate="true" name="com.example.test" activate="activate" deactivate="deactivate"/>
  <service>
  </service>
</scr:component>
Obviously I am still missing a piece of the puzzle. I have spent numerous hours searching the web for a hint or a complete example, to no avail.
So, as always, any help is greatly appreciated.
Kind Regards,
Erwin
Re: ApplicationConfiguration DS example [message #1061005 is a reply to message #1060972] Wed, 29 May 2013 09:38 Go to previous messageGo to next message
Hi Erwin,
just use New Project Wizard and create a project based on "RAP Hello
World" template. The generated project uses DS.
[1]
http://www.eclipse.org/rap/developers-guide/devguide.php?topic=hello-world.html&version=2.0
Best,
Ivan
On 5/29/2013 2:29 PM, Erwin Hogeweg wrote:
> <service>
> <provide
> </service>
> </scr:component>
> <service>
> <provide
> </service>
> </scr:component>
> no avail.
> Kind Regards,
> Erwin
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: ApplicationConfiguration DS example [message #1061013 is a reply to message #1060972] Wed, 29 May 2013 09:46 Go to previous messageGo to next message
Erwin,
it seems that you're still using RAP 1.5. If you're experimenting with
RAP, it's probably better to start with RAP 2.0 or 2.1, since there are
a lot of changes between 1.x and 2.x.
If you're unsure if your ApplicationConfiguration is properly registered
as a service, you can check the Equinox console:
osgi> services *ApplicationConfiguration
{org.eclipse.rap.rwt.application.ApplicationConfiguration}={component.name=org.eclipse.rap.demo.controls,
component.id=0, service.id=66}
"Registered by bundle:" org.eclipse.rap.demo.controls_2.1.0.qualifier
[16]
"Bundles using service"
org.eclipse.rap.rwt.osgi_2.1.0.qualifier [7]
Here's a code example for a simple project that uses DS:
https://github.com/ralfstx/rap-helpers/tree/master/example.rwt.simple.ds
Ralf
Ralf Sternberg
Re: ApplicationConfiguration DS example [message #1061068 is a reply to message #1061013] Wed, 29 May 2013 14:39 Go to previous message
Ralf,
I wondered why you said this:
... because I am using 2.0! So I checked out your example, and it looked the same as my code, at least, that't what I though. until I spotted the typo in the ApplicationConfiguration package name in the component definition... inserted the ".rap", and everything fell magically in place.
I must have copied that from a 1.5 sample project and forgot to update to the new package names.
I am rolling again, thanks for your help.
Kind Regards,
Erwin
Previous Topic:white screen when waiting for response
Next Topic:Toolbar height
Current Time: Thu Jul 24 23:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.28074 seconds
