Home » Modeling » ATL » ATL Metamodel(Looking for ATL metamodel)
ATL Metamodel [message #1060991] Wed, 29 May 2013 09:07 Go to next message
Anyone knows if exist and where I can find a metamodel for ATL, i.e., a metamodel that describe ATL himself, to allow me to transform something in .ATL using ATL transformations.
Re: ATL Metamodel [message #1061036 is a reply to message #1060991] Wed, 29 May 2013 11:56 Go to previous messageGo to next message
The ATL metamodel (implemented in Ecore) can be found from the org.eclipse.m2m.atl.dsls plugin (in its folder resources you will also find all the other metamodels internally used by ATL).
Re: ATL Metamodel [message #1061040 is a reply to message #1061036] Wed, 29 May 2013 11:59 Go to previous messageGo to next message
Note that you can inject ATL files (*.atl) as ATL models, and extract ATL models as ATL files, using the ATL ANT tasks for instance.
Re: ATL Metamodel [message #1062315 is a reply to message #1060991] Fri, 07 June 2013 03:24 Go to previous messageGo to next message
Pedro here you are the "ecorediag" generated by the ATL Metamodel and ordered by Javier Troya.
https://www.dropbox.com/s/quuz7mm5vfn9v23/ATLEcorediag.png
Antonio
Re: ATL Metamodel [message #1065147 is a reply to message #1062315] Mon, 24 June 2013 09:52 Go to previous messageGo to next message
Thanks a lot Hugo, its exactly what I was looking for.
Re: ATL Metamodel [message #1066237 is a reply to message #1060991] Mon, 01 July 2013 12:04 Go to previous messageGo to next message
Now, I would like to know how can I get java code from .ecore metamodel (in this case from atl.ecore) like it's possible, for example, with UML.
Re: ATL Metamodel [message #1066251 is a reply to message #1066237] Mon, 01 July 2013 13:33 Go to previous message
I think this is more related to EMF itself (Java method calls from Ecore files/models), and not to ATL.
You should try to post your question onto the EMF forum.
Previous Topic:How to specify in the rule that one element contain another
Next Topic:EMFTVM - Matched rules do not match cross referenced model elements
Current Time: Sun Jul 27 14:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.05616 seconds
