Home » Modeling » TMF (Xtext) » How to implement such a different ImportedNamespace?
How to implement such a different ImportedNamespace? [message #1060981] Wed, 29 May 2013 08:16 Go to next message
Hi all,
Xtext documentation (15 Minutes Tutorial) gives an example to implement the following language (the main purpose is to show how to use importedNamespace to support 'Packages" and 'Import').
    // datatypes.dmodel, the first file
    datatype String
    // commons.dmodel, the second file
    package my.company.common {
       entity HasAuthor {
          author: String
    // blogs.dmodel, the third file
    package my.company.blog {
       import my.company.common.*
       entity Blog {
          title: String
          many posts: Post
       entity Post extends my.company.common.HasAuthor {
          title: String
          content: String
          many comments: Comment
       entity Comment extends HasAuthor {
          content: String
The following is the full grammar.
grammar org.example.domainmodel.Domainmodel with
    org.eclipse.xtext.common.Terminals
    generate domainmodel "www.example.org/domainmodel/Domainmodel"
    Domainmodel:
       (elements += AbstractElement)*
    PackageDeclaration:
        'package' name = QualifiedName '{'
    AbstractElement:
        PackageDeclaration | Type | Import
    QualifiedName:
        ID ('.' ID)*
    Import:
       'import' importedNamespace = QualifiedNameWithWildcard
    QualifiedNameWithWildcard:
        QualifiedName '.*'?
    Type:
        DataType | Entity
    DataType:
        'datatype' name=ID
    Entity:
      'entity' name = ID ('extends' superType = [Entity | QualifiedName])? '{'
         (features += Feature)*
    Feature:
        (many ?= 'many')? name = ID ':' type = [Type | QualifiedName]
However, I want my language to support the following 'Import' mechanism.
import * from my.company.common // equivalent to "import my.company.common.*"
import my.company.common // no '.*', equivalent to "import my.company.common.*"
import HasAuthor from my.company.common // equivalent to "import my.company.common.HasAuthor", that is, only "HasAuthor" is imported
Could anyone please give some advices on how to implement this kind of 'Import' mechanism? Thanks in advance!
Best Regards,
Matthew
[Updated on: Sun, 02 June 2013 05:07] by Moderator
Re: How to implement such a different ImportedNamespace? [message #1061361 is a reply to message #1060981] Fri, 31 May 2013 06:25 Go to previous messageGo to next message
if I see it correctly, this is matter of binding your own ImportedNamespaceAwareLocalScopeProvider and override the method internalGetImportedNamespaceResolvers. Your imports are just a syntactic variant of the normal imports. So adapting the grammar along the following line should be a way to go
Import: (lastSegment=('*'|ID))? 'from' qname=QualifiedName;
In the above methods you simple callect all relevant Import objects and create the corresponding QualifiedName with potential wild card.
A datatype rule
Import: (ID|'*')? 'from' QualifiedName;
might be an option as well. In this case you would not have to adapt the scope provider, but you will have to register a value converter turning the String into a properly formed qualified name with wild card.
At the moment, I would tend to take option one.
Alex
Re: How to implement such a different ImportedNamespace? [message #1061788 is a reply to message #1061361] Tue, 04 June 2013 01:13 Go to previous message
Hello Alex,
Thanks a lot for your advice!
Best Regards,
Matthew Liu
Previous Topic:how to use xtext features in a html textarea
Next Topic:Errors after upgrading from Xtext 2.3 to 2.4
Current Time: Wed Jul 23 16:10:58 EDT 2025
Powered by FUDForum. Page generated in 1.24231 seconds
