Home » Modeling » TMF (Xtext) » "a registered resource factory is needed" error with absolute path
"a registered resource factory is needed" error with absolute path [message #1060915] Wed, 29 May 2013 03:02 Go to next message
I have an xtext.jar file that I try to run in DOS command line.
When I try to use the absolute path for my input file, I am getting an error "Cannot create a resource for 'D:\01\Sample\Test\Mod1\sample.txt'; a registered resource factory is needed." This is the command I used:
java -jar xtext.jar D:\01\Sample\Test\Mod1\sample.txt
But, when I use relative paths, the jar file will work without any error.
java -jar xtext.jar Mod1\sample.txt
Anyone has any idea why this is so?
Re: "a registered resource factory is needed" error with absolute path [message #1060918 is a reply to message #1060915] Wed, 29 May 2013 03:17 Go to previous messageGo to next message
Could be that "D:" is recognized as URI scheme. Try to prefix with "file:".
Re: "a registered resource factory is needed" error with absolute path [message #1060950 is a reply to message #1060918] Wed, 29 May 2013 05:31 Go to previous messageGo to next message
I tried File:\\D:\01\Sample\Test\Mod1\sample.txt, but still the same error. Am I using it the wrong way?
In my workflow, I have disabled these for importURI.
// scoping and exporting API
// fragment = scoping.ImportURIScopingFragment {}
// fragment = exporting.SimpleNamesFragment {}
Could this be the reason?
Re: "a registered resource factory is needed" error with absolute path [message #1061010 is a reply to message #1060950] Wed, 29 May 2013 09:44 Go to previous message
Chris,
If this API wants a URI, keep in mind that \ is not a segment separator
in a URI (it's treated just like other punctuation as as "-" or "_") ,
so perhaps file:/D:/01/Sample/Test/Mod1/sample.txt would work properly
Previous Topic:Automatically adding Xtext nature to project
Next Topic:JvmModelInferrer: multiple input files
Current Time: Sat Jul 26 01:13:13 EDT 2025
Powered by FUDForum. Page generated in 0.47573 seconds
