Home » Eclipse Projects » Remote Application Platform (RAP) » white screen when waiting for response
white screen when waiting for response [message #1060946] Wed, 29 May 2013 05:16 Go to next message
after switching from RAP 1.5.1 to 2.1 M2 I always got white screens, when doing some action in the application. The application is running on a JBoss AS 7 server. When I start the app locally with jetty I got a nice light grey transparent screen and see an action wheel. Is this possible on war installations too?
thx, Dirk
Re: white screen when waiting for response [message #1061001 is a reply to message #1060946] Wed, 29 May 2013 09:34 Go to previous messageGo to next message
Hi Dirk,
do you have your own custom theme? It seems that during the migration
from 1.5.1 to 2.1 M2 your theme is not updated with all the needed
properties from RAP 2.0+. Or... in case it is, the theme (CSS) is not
included in the war.
Best,
Ivan
On 5/29/2013 4:02 PM, Dirk Polke wrote:
> Hello,
> thx, Dirk
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: white screen when waiting for response [message #1061117 is a reply to message #1061001] Thu, 30 May 2013 02:55 Go to previous messageGo to next message
Hello Ivan,
I have activated from the examples the business theme, which looks like as expected...
regards, Dirk
Re: white screen when waiting for response [message #1065699 is a reply to message #1061117] Thu, 27 June 2013 04:05 Go to previous messageGo to next message
Hey,
I have the same problem than you, have you found any solution?
thx André
Re: white screen when waiting for response [message #1065818 is a reply to message #1065699] Thu, 27 June 2013 11:19 Go to previous messageGo to next message
Hi André,
please look at your theme about the following CSS:
SystemMessage-DisplayOverlay {
background-color: rgba( 128, 128, 128, 0.3 );
background-image: none;
Do you have it? If not add it to your theme and try again.
HTH,
Ivan
On 6/27/2013 5:27 PM, André Kemter wrote:
> Hey,
> thx André
Ivan Furnadjiev
Re: white screen when waiting for response [message #1066133 is a reply to message #1065818] Mon, 01 July 2013 03:59 Go to previous messageGo to next message
Thank you Ivan for your answer it fixed the problem. Smile
André
[Updated on: Mon, 01 July 2013 04:15] by Moderator
Re: white screen when waiting for response [message #1066145 is a reply to message #1066133] Mon, 01 July 2013 05:27 Go to previous messageGo to next message
André,
when a response from the server is delayed, the screen is blocked by an
overlay to prevent further interaction. The look of this overlay can be
changed in the theme, as Ivan explained.
However, you shouldn't usually see this overlay often, unless you have
an unusually long network latency. If you do anyway, you should have a
look at the response times.
Long response times can be caused by time-consuming operations running
directly in the UI thread. Could this be the case in your application?
Ralf
Ralf Sternberg
Re: white screen when waiting for response [message #1066222 is a reply to message #1066145] Mon, 01 July 2013 11:06 Go to previous messageGo to next message
I had made a mistake, but now it works with the solution from Ivan.
But Ralf thank you for helping.
Yours sincerely
André
Re: white screen when waiting for response [message #1066759 is a reply to message #1066222] Thu, 04 July 2013 05:04 Go to previous message
Hi again,
solved for me now too, after deleting all temporary files on the jboss server and undeploying the application. I also added the latest example design to the war file.
regards, Dirk
Previous Topic:deploying on tomcat6
Next Topic:ApplicationConfiguration DS example
Current Time: Fri Jul 25 19:46:32 EDT 2025
Powered by FUDForum. Page generated in 0.04781 seconds
