Home » Archived » Hudson » Hudson remote api usage(Hudson remote api usage)
Hudson remote api usage [message #1058474] Tue, 14 May 2013 05:50 Go to next message
I want to use hudson remote apis to create job,build jobs.
To create job i have used the below code,
The job is created,but the response i got is 400 error,Bad request.
Shall i use the config.xml present in jobs folder for one of the jobs which i have created earlier.
Please explain the reason for 400 error and how come the job got created.
Please help me out in solving this.
Re: Hudson remote api usage [message #1058749 is a reply to message #1058474] Tue, 14 May 2013 17:06 Go to previous messageGo to next message
What code?
What version of Hudson are you running? Do you have authentication on?
Thanks.
Re: Hudson remote api usage [message #1059541 is a reply to message #1058749] Mon, 20 May 2013 07:36 Go to previous messageGo to next message
Hi All,
Running Hudson as the service in 8080 port.Iam have wrote sample java code to create job in hudson and trigger it from the remote windows machine.The config.xml is taken from the jobs folder of another job:
But it is throwing 500 error(Response status code: 500
package createJob;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import org.apache.commons.httpclient.HttpClient;
import org.apache.commons.httpclient.methods.InputStreamRequestEntity;
import org.apache.commons.httpclient.methods.PostMethod;
public class CreateJob {
	public static void main(String[] args) throws FileNotFoundException {
		String strURL = "htt://XXXX:8080/createItem?name=findsresume123";
		File input = new File("C:\\Users\\XXXX\\Desktop\\config.xml");
		PostMethod post = new PostMethod(strURL);
		post.setRequestEntity(new InputStreamRequestEntity(new FileInputStream(input), input.length()));
		post.setRequestHeader("Content-type", "text/xml; charset=ISO-8859-1");
		HttpClient httpclient = new HttpClient();
		try {
            int result = httpclient.executeMethod(post);
            System.out.println("Response status code: " + result);
            System.out.println("Response body: ");
            System.out.println(post.getResponseBodyAsString());
		catch (Exception e) {
            // Release current connection to the connection pool
            // once you are done
            post.releaseConnection();
		// TODO Auto-generated method stub
Response body:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 500 Unable to read /var/lib/hudson/jobs/yyyy/config.xml</title>
</head>
<body><h2>HTTP ERROR 500</h2>
<p>Problem accessing /createItem. Reason:
<pre>    Unable to read /var/lib/hudson/jobs/yyyy/config.xml</pre></p><h3>Caused by:</h3><pre>hudson.util.IOException2: Unable to read /var/lib/hudson/jobs/yyyy/config.xml
	at hudson.XmlFile.read(XmlFile.java:119)
	at hudson.model.Items.load(Items.java:113)
	at hudson.model.ItemGroupMixIn.createProjectFrom
        at hudson.model.ItemGroupMixIn.createTopLevelItem(ItemGroupMixIn.java:161)
	at hudson.model.Hudson.doCreateItem(Hudson.java:2676)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.kohsuke.stapler.Function$InstanceFunction.invoke(Function.java:274)
	at org.kohsuke.stapler.Function.bindAndInvoke(Function.java:141)
	at org.kohsuke.stapler.Function.bindAndInvokeAndServeResponse(Function.java:80)
	at org.kohsuke.stapler.MetaClass$1.doDispatch(MetaClass.java:95)
	at org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:45)
	at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:565)
	at org.kohsuke.stapler.Stapler.invoke(Stapler.java:650)
	at org.kohsuke.stapler.Stapler.invoke(Stapler.java:481)
	at org.kohsuke.stapler.Stapler.service(Stapler.java:152)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
	at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:86)
	at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:78)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
	at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:81)
	at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:73)
	at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:157)
	at hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:534)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
	at org.eclipse.jetty.server.Server.handle(Server.java:365)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
	at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:937)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:998)
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:856)
	at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
	at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
	at java.lang.Thread.run(Thread.java:679)
Caused by: com.thoughtworks.xstream.converters.ConversionException:  : no more data available - expected end tag &lt;/project&gt; to close start tag &lt;project&gt; from line 2, parser stopped on END_TAG seen ...&lt;builders/&gt;\r\n... @205:1 :  : no more data available - expected end tag &lt;/project&gt; to close start tag &lt;project&gt; from line 2, parser stopped on END_TAG seen ...&lt;builders/&gt;\r\n... @205:1
---- Debugging information ----
I have not turn on authentication.
version-hudson-3.0.1.If i need turn on authentication please explain the steps too.
Please help me out in resolving this
[Updated on: Tue, 21 May 2013 08:12] by Moderator
Re: Hudson remote api usage [message #1059626 is a reply to message #1059541] Mon, 20 May 2013 17:54 Go to previous messageGo to next message
You should not use createItem directly. You should use the remote Access API as explained here http://wiki.hudson-ci.org/display/HUDSON/Remote+access+API.
Re: Hudson remote api usage [message #1059743 is a reply to message #1059626] Tue, 21 May 2013 09:24 Go to previous messageGo to next message
I have configured security and enabled it as mentioned in the url:
http://wiki.hudson-ci.org/display/HUDSON/Standard+Security+Setup
I have created users and give all permissions to create job
I have modified the code as accessing the url with username and password which i created now.
Create Job
I have created the job as mentioned below in the site.
To create a new job, POST config.xml to http://your_server/createItem (copy url) with query parameter name=JOBNAME.
You'll get 200 status code if the creation is successful, or 4xx/5xx code if it fails. config.xml is the format Hudson uses to store the job in the file system, so you can see examples of them in /var/lib/hudson.
I have tried the code as mentioned in the site:"http://wiki.hudson-ci.org/display/HUDSON/Authenticating+scripted+clients"
There also they have used the createItem directly.
Can you please explain briefly,so that it can be useful for me.
Thanks.
[Updated on: Tue, 21 May 2013 09:25] by Moderator
Re: Hudson remote api usage [message #1059997 is a reply to message #1059743] Wed, 22 May 2013 09:38 Go to previous messageGo to next message
Please help me out in resolving this.
HariPrasadh
Re: Hudson remote api usage [message #1060060 is a reply to message #1059997] Wed, 22 May 2013 14:33 Go to previous messageGo to next message
I'll look at it and get back to you.
Re: Hudson remote api usage [message #1060079 is a reply to message #1060060] Wed, 22 May 2013 21:38 Go to previous messageGo to next message
Mean while you can take a look at Hudson Job Creator tool
Re: Hudson remote api usage [message #1060936 is a reply to message #1060079] Wed, 29 May 2013 04:43 Go to previous messageGo to next message
Thanks winston.I ran the same code today.It ran properly and created job with status code 200(success).
Re: Hudson remote api usage [message #1062209 is a reply to message #1060936] Thu, 06 June 2013 10:10 Go to previous messageGo to next message
Hi Winston,
Now iam getting problem in triggering the build remotely.
The code is
public String buildjob()
String strURL1="htt://xxxx:8080/job/"+jobname+"/build?delay=0sec";
PostMethod post = new PostMethod(strURL1);
httpclient.getState().setCredentials(new AuthScope("xxxx", 8080, "realm"),new UsernamePasswordCredentials("xxxx", "zzzz"));
httpclient.getParams().setAuthenticationPreemptive(true);
try {
System.out.println("Build Response status code: " + result);
System.out.println("Build Response body: ");
return res;
Iam getting 302 response code.buthe build is happening at hudson end.i was not able to get the build is success/failure.
Please share some idea to get the build no,build status and check the above code and let me know.
Re: Hudson remote api usage [message #1062361 is a reply to message #1062209] Fri, 07 June 2013 08:16 Go to previous messageGo to next message
Please check the above issue.its little urgent.
HariPrasadh
Re: Hudson remote api usage [message #1063474 is a reply to message #1062361] Thu, 13 June 2013 05:24 Go to previous messageGo to next message
Please someone reply me to my above query.
HariPrasadh
Re: Hudson remote api usage [message #1063653 is a reply to message #1063474] Thu, 13 June 2013 11:23 Go to previous messageGo to next message
Hari, let us take this offline. Send me an e-mail at winston DOT prakash AT gmail DOT com. Once you have a correct solution you can post it here.
Re: Hudson remote api usage [message #1065360 is a reply to message #1063653] Tue, 25 June 2013 08:32 Go to previous message
Hello Wiston,
I have sent a mail to you stating the problem.Please help.
HariPrasadh
Previous Topic:How can we execute Hudson\Jenkins Job using logged on user credential
Next Topic:svn update with revert not working
Current Time: Wed Jul 23 21:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.06966 seconds
