Home » Archived » BIRT » Importing or creating a database with BIRT
Importing or creating a database with BIRT [message #1060695] Mon, 27 May 2013 17:58 Go to next message
Hello!
I'm sorry if this post is going to sound stupid, but I'm new at BIRT. I have to use it for a school report and I'm having some trouble with importing data sources and data sets.
I was wandering if there is a way of creating a database in Eclipse and then importing it as a data source? If no, how do you import a database created in SQL Server or in a different program?
I have to create a data warehouse and import it into BIRT so that I can create a few reports.
Thank you in advance for answering and again, I'm sorry for asking a stupid question Sad
Re: Importing or creating a database with BIRT [message #1060877 is a reply to message #1060695] Tue, 28 May 2013 15:39 Go to previous messageGo to next message
To connect to a db like mySQL from BIRT you'll need to create a new data source. You'll want to select "JDBC Data Source". Next you'll need to tell BIRT what driver you're wanting to use, for mySQL I use com.mysql.jdbc.Driver (v5.1).
Next you'll need to provide it a url to your database, if mySQL is on the same machine that you are creating the reports on it'd be something like
jdbc+mysql://localhost:3306/databasename
Then you'll need to give it your user name and password. You should test the connection first with the test connection button to make sure everything is correct.
After you've created a data source you can create a new data set. You'll have to provide it a query, a simple one would be something like
select *
from TABLE_NAME
If you're wanting to connect to another type of db you can select it while creating your data source in the first prompt.
If you need help with your SQL query http://dev.mysql.com/doc/refman/5.0/en/select.html is a good site that you might want to look over.
[Updated on: Tue, 28 May 2013 15:41] by Moderator
Re: Importing or creating a database with BIRT [message #1060928 is a reply to message #1060877] Wed, 29 May 2013 04:15 Go to previous message
Thank you very much! Smile
Previous Topic:org.eclipse.birt.report.service.api.ReportServiceException
Next Topic:kindly help me
Current Time: Thu Jul 17 19:40:24 EDT 2025
Powered by FUDForum. Page generated in 0.27603 seconds
