Home » Modeling » TMF (Xtext) » How to define a 'synchronized' method using the model inferrer
How to define a 'synchronized' method using the model inferrer [message #1060821] Tue, 28 May 2013 10:05 Go to next message
Hi all,
I'm using the model inferrer in order to map elements in a model into Java methods. E.g., I have this code:
members += model.toMethod("foo", model.newTypeRef(Void::TYPE)) [
body = [ append('''...''') ]
Is it possible to define the above Java method as 'synchronized'? I hope it is...
Thanks!
Oren
Re: How to define a 'synchronized' method using the model inferrer [message #1060831 is a reply to message #1060821] Tue, 28 May 2013 10:48 Go to previous messageGo to next message
On 05/28/2013 04:05 PM, Oren Mishali wrote:
> Hi all,
> it is...
Just inspect the JvmOperation and you can see the get/setSynchronized :)
synchronized = true
HOME: http://www.lorenzobettini.it
Re: How to define a 'synchronized' method using the model inferrer [message #1060910 is a reply to message #1060831] Wed, 29 May 2013 02:44 Go to previous message
Thanks!
I missed that since I'm using Xtext 2.3 (set/getSynchronized are only available since 2.4). It is the time to update...
Oren
Previous Topic:Add my var in Quick Reference
Next Topic:Correct Indentation
Current Time: Wed Jul 23 06:13:39 EDT 2025
Powered by FUDForum. Page generated in 0.28730 seconds
