[EMF] Change volatile and transient properties [message #1060651] |
Mon, 27 May 2013 09:31  |
When I store some instances of an ECore model and then change violate value, would I have an error when I try to read the file and what kind of exception will occur?
And the same question about transient. If something is transient=true and then is changed to false. If i have instancies from the old ECore model, should I expect some kind of errors? And when transient=false and gets changed to transient=true. Would the stored values be ignored, or I'll recieve an error?
Aleksandar
[Updated on: Mon, 27 May 2013 09:32] by Moderator
Re: Change volatile and transient properties [message #1060760 is a reply to message #1060651] |
Tue, 28 May 2013 07:44   |
Aleksandar,
Comments below.
On 27/05/2013 3:31 PM, Aleksandar Toshovski wrote:
> Hello,
That setting only affects the generated code, bug given that no field
will be generated and only stubs that throw exceptions for the accessors
are generated, so that won't work without some hand written code.
Transient things in the serialization won't generally cause exceptions
in deserialization (except possibly in cases of bidirectional
references; I'm not sure).
They'll generally just be read into the model, but won't be written back
out again.
> Regards,
> Aleksandar
Re: Change volatile and transient properties [message #1060995 is a reply to message #1060940] |
Wed, 29 May 2013 09:19  |
No. Generally if you make changes that are binary compatible in the
Java API sense, you'll not have problems loading.
Note there's also an option,
org.eclipse.emf.ecore.xmi.XMLResource.OPTION_RECORD_UNKNOWN_FEATURE,
which can be used to support forward compatibility, i.e., an older
version of the tool can read newer serializations and will record
elements and attributes that are unrecognized in such a fashion that
they can be serialized back out again upon save.
On 29/05/2013 11:06 AM, Aleksandar Toshovski wrote:
> Thank you Ed for your reply. Is there any documentation describing
> which changes of the metamodel will cause an error in the EMF Editor?
FUDForum. Page generated in 0.07486 seconds
