Home » Modeling » TMF (Xtext) » Maven errors question
Maven errors question [message #1060731] Tue, 28 May 2013 05:30 Go to next message
Hello folks
I was wondering if I could get some help with my maven setup?
I have been using this example as my base for building my maven setup, but since I only need the jar file and not a compilation I have modded the mydsl pom file.
When I extract it in eclipse as runnable jar with the option "Package required libraries into generated Jar" everything works fine, but when I build and run the jar with maven I get the following errors:
----------------------ERROR--------------------------------------
log4j:WARN No appenders could be found for logger (org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser).
log4j:WARN Please initialize the log4j system properly.
Exception in thread "main" org.eclipse.emf.common.util.WrappedException: java.lang.StringIndexOutOfBoundsException:
String index out of range: 369
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:182)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:135
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:11
4)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:510)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:154)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:67)
at idainfront.iipax.dsl.generator.Generator.runGenerator(Generator.java:42)
at idainfront.iipax.dsl.generator.Main.main(Main.java:32)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 369
at java.lang.String.substring(Unknown Source)
at org.eclipse.xtext.nodemodel.impl.AbstractNode.getText(AbstractNode.java:95)
at org.eclipse.xtext.nodemodel.util.NodeModelUtils.getTokenText(NodeModelUtils.java:373)
at org.eclipse.xtext.linking.impl.LinkingHelper.getCrossRefNodeAsString(LinkingHelper.java:51)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getCrossRefNodeAsString(DefaultLinkingService.java:1
39)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:115)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:198)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:175)
... 7 more
I don't really know what files may help you I thought atleast I might post the pom for this file and the mydsl (which is iidsl for me) projects.
Generator pom
IiDSL pom
Hmm... might as well ask, but since I only want to compile a jar file from my main class which turns my dsl file into an xml file by using the generator, do I need to build all the projects they have in the xtext-maven-example or can I simplify it?
(Cinda new to maven Smile )
Thanks for any help
Write you later / Mårten
Re: Maven errors question [message #1060735 is a reply to message #1060731] Tue, 28 May 2013 05:40 Go to previous messageGo to next message
did you make sure you did not stumbe over http://www.eclipse.org/forums/index.php/m/1022283/?srch=xtext-maven-examples#msg_1022283
Re: Maven errors question [message #1060737 is a reply to message #1060735] Tue, 28 May 2013 05:49 Go to previous messageGo to next message
I should probably have mentioned it. But I did stumble over it, fell quite hard and no wiser when I got up Smile
I tried to remove the log4j and repackage them in the standalone but it didn't seem to help.
I guess I missed something so will look into it again.
Well, sorry for taking your time if the answer already was here Smile
Re: Maven errors question [message #1060740 is a reply to message #1060737] Tue, 28 May 2013 06:02 Go to previous messageGo to next message
HI,
i fear you have to do some further digging on that place
Re: Maven errors question [message #1060741 is a reply to message #1060740] Tue, 28 May 2013 06:09 Go to previous message
meh! Sorry for taking up your time. Seems I forgot to fix in the repackage.xml file.
Now I only have the log4j warning but... since it compiles I will take that when I have more time Smile
Sorry again, its like when you ask the teacher about something and just as you ask you find the answer.
Well, at least people here have good patience with me Very Happy
Have a good day
Previous Topic:Scoping specific GMF elements in xtext grammar
Next Topic:New Target Language
Current Time: Sat Jul 26 11:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.24646 seconds
