Home » Modeling » EMF » Run generated Editors in Eclipse4 RCP(Troubles using EMF generated editors in Eclipse4 RCP)
Run generated Editors in Eclipse4 RCP [message #1060687] Mon, 27 May 2013 15:44 Go to next message
I know it is highly related to Eclipse4 framework but I believe it is more appropriate to publish this question in this forum.
I started to test Eclipse4 framework. So far, it is going well with the 3.x compatibility layer. I try to build a Eclipse4 RCP application that includes an EMF generated Editor. The product starts properly but I get an error the first time the generated EMF editor is invoked (new model instance | simple open in the Navigator view). It complaints about "cannot find ID additions" (Popup menu entry point). I close the editor and try a second time and now it works. I believe there is a bundle startlevel that must set to resolve this issue but I do not know which one. If I navigate the model instance, the editor fails when right-clicking to get the popup menu. Is it possible to run EMF generated editor in Eclipse4?
I created a simple Eclipse4 RCP that reflects this.
-test (EMF model including Root that contains multiple Element.
-test.edit
-test.editor
-test.rcp (Product, E4 application etc).
Eclipse Build
-Eclipse 4.3RC1 (I20130516-2200)
-EMF Common 2.9.0.v20130515-0805
-EMF Ecore 2.9.0.v20130515-0805
-XCore 1.1.0.v20130522-0607
Steps to reproduce the problem:
1) Import the exiting projects (zip in attachment)
2) Open test.rcp->test.rcp.product
3) Launch an Eclipse Application (this will fail).
4) Go in Run->Run Configurations..
5) Select Ecplise Application->test.rcp.product
6) Select Plug-ins tab
7) Click on Add Required Plug-ins
Cool Click on Run
9) In the Navigation View, create a new project named test (Right-Click -> New -> Project...)
10) Select the project test, right-click New->Other->Example EMF Model Creation Wizards->Test Model, Click on Next
11) Set the name of the file (ex. My1.test).
12) In the Model Object combo box select Root then Finish.
13) You get the editor opening error (see Log View in the bottom)
14) Close the editor
15) Open My1.test
16) Now the editor works.
17) Browse the EMF instance and select Root element.
18) Right-click to invoke the popup menu.
19) You get the popup menu error. (see Log view in the bottom).
Re: Run generated Editors in Eclipse4 RCP [message #1060713 is a reply to message #1060687] Tue, 28 May 2013 04:06 Go to previous messageGo to next message
On 27-05-13 21:44, Régent L Archevêque wrote:
Hi Regent,
It's not an answer to your question, but perhaps this project would be
of your interest.
https://github.com/dzonekl/e4mf
rgds Christophe
> -test.edit
> -test.editor
> Eclipse Build
> 8) Click on Run
> 15) Open My1.test
Re: Run generated Editors in Eclipse4 RCP [message #1060764 is a reply to message #1060687] Tue, 28 May 2013 07:45 Go to previous messageGo to next message
Régent,
I won't have time to look until later this week. Please open a bugzilla
with the details and I'll try to reproduce it and fix or redirect it as
appropriate.
On 27/05/2013 9:44 PM, Régent L Archevêque wrote:
> -test.edit
> -test.editor
> Eclipse Build
> 8) Click on Run
> 15) Open My1.test
Re: Run generated Editors in Eclipse4 RCP [message #1060804 is a reply to message #1060764] Tue, 28 May 2013 09:14 Go to previous messageGo to next message
Ok. I'll post a bug on this. Meanwhile I continue my investigation!!!
Thanks Wink
Re: Run generated Editors in Eclipse4 RCP [message #1060811 is a reply to message #1060687] Tue, 28 May 2013 09:39 Go to previous messageGo to next message
I posted bug [url=https://bugs.eclipse.org/bugs/show_bug.cgi?id=409283]
I made some check and I realize that if I change in the Run Configurations...
Run a product -> org.eclipse.sdk.ide
Run an application -> org.eclipse.ui.ide.workbench
Then it works!
Re: Run generated Editors in Eclipse4 RCP [message #1060822 is a reply to message #1060811] Tue, 28 May 2013 10:14 Go to previous message
Just to be clear in my previous post. It works with the Eclipse SDK application but not with my RCP application.
Wink
Previous Topic:[CDO] ArrayIndexOutOfBoundsException on rollback
Next Topic:define getter of derived volatile attribute
Current Time: Sat Aug 30 13:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.03679 seconds
