Home » Modeling » EMF » problem with inheritance and access to subclass( problem with inheritance and access to subclass)
problem with inheritance and access to subclass [message #1060382] Fri, 24 May 2013 07:20 Go to next message
hi, I have a problem with inheritance and access to subclass
My EMF Model has a superclass called Component and two subclasses of Component called Primitive and Composite.
to print the Component name I have to do:
// Create a resource for this file.
Resource resource = resourceSet.createResource(uri);
resource.load(null);
Systeme s = (Systeme)resource.getContents().get(0);
EList< Component > list1 = s.get Components ();
Iterator i1 = list1.iterator();
while (i1.hasNext()){
Component c =( Component) i1.next();
java.lang.System.out.println("Component name : "+c.getNom);
but now I want to have access to the subclass and then print their name, so I want to do somthing like this
Component:
type: Primitive : component name
Component:
type: Composite : component name
my first attempt was
EList<Primitive> list2 = c.getPrimitives();//  but c have no access to here subclass!!
Iterator i2 = list2.iterator();
while (21.hasNext()){
Primitive p =(Primitive) i2.next();
java.lang.System.out.println("process "+ p.getNom()+" ("+ " ) {");
but c have no access to here subclass Crying or Very Sad !!
pleas help me to print the name of the subclass Sad
I hope that the problem is well explained
Re: problem with inheritance and access to subclass [message #1060427 is a reply to message #1060382] Fri, 24 May 2013 11:18 Go to previous messageGo to next message
Amina,
Comments below.
It's better to use resourceSet.getResource(uri, true) for this.
Using "for (Component c: s.getComponents())" seems more elegant...
> Component:
> Component:
Xtend supports switches on types, but in Java you can only use normal
"instanceof" testing. EMF also supports a generated XyxSwitch that you
can specialize to handle casePrimitive and caseComposite; that can
perform much better when there are many cases to cover, but for this
simple example, an instanceof test seems sufficient.
> here subclass!!
> but c have no access to here subclass :cry: !!
What do you mean by "no access mean"? The way you've modeled it you'd
have to iterate over all the components and check each one to see if
it's Primitive or Composite.
> pleas help me to print the name of the subclass :( I hope that the
Re: problem with inheritance and access to subclass [message #1060563 is a reply to message #1060427] Sun, 26 May 2013 18:05 Go to previous messageGo to next message
I have the same problem Crying or Very Sad
Re: problem with inheritance and access to subclass [message #1060643 is a reply to message #1060563] Mon, 27 May 2013 08:54 Go to previous message
So the same answer applies...
On 27/05/2013 2:33 PM, Fatima Salhi wrote:
> I have the same problem :cry:
Previous Topic:[CDO] Understanding proxy state.
Next Topic:[Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP
Current Time: Wed Jul 30 23:03:50 EDT 2025
Powered by FUDForum. Page generated in 0.03275 seconds
