Home » Modeling » Papyrus » model validation problem sequence diagram
model validation problem sequence diagram [message #1060544] Sun, 26 May 2013 11:04 Go to next message
I validated my model and Papyrus complains (multiple time) about:
"The required feature 'action' of '<Action Execution Specification>
DisplayInitialiseAction' must be set"
where "DisplayInitialiseAction" is different each time, depending on the
concrete action.
It happens whenever I have a syncCall in a sequence diagram that ends in
a "Action Execution Specification" and I do not specify the "Action",
i.e. it says "<Undefined>" in the UML properties.
I can make it disappear by letting it end in a "Behaviour Execution
Specification" but what should I do to make it disappear by maintaining
the "Action Execution Specification", because it is actually an action,
and not a behaviour?
TIA
Joost
Re: model validation problem sequence diagram [message #1060567 is a reply to message #1060544] Mon, 27 May 2013 01:52 Go to previous messageGo to next message
Hi Joost,
without providing an explicit Action, you cannot do anything to let the
validation problem disappear. This is not an arbitrary validation rule
specified by Papyrus, but a syntactic obligation of the UML metamodel. An
ActionExecutionSpecification requires an action to be valid. Riddle solved!
Marc-Florian
"Joost Kraaijeveld" wrote in message news:knt8a9$rld$1@xxxxxxxxe.org...
concrete action.
TIA
Joost
Re: model validation problem sequence diagram [message #1060604 is a reply to message #1060567] Mon, 27 May 2013 05:38 Go to previous messageGo to next message
Hi Marc-Florian,
Thanks for the answer.
On 27-05-13 07:52, Marc-Florian Wendland wrote:
> Hi Joost,
> An ActionExecutionSpecification requires an action to be valid. Riddle
> solved!
I should have asked the right question ;-).
The practical problem at hand hand is that if I select the "+" just
right after the action I can choose between ~41 actions. If I select
CallBehaviorAction or CallOperationAction (and many other actions) I
have to choose "a parent element of the new object". I have no idea what
to choose from the options that are given. Most things are greyed out,
but some become active if I click on them. But I have no idea which
should or could be the right one. Should the interaction (which is
displayed by the sequence diagram) that contains the lifeline with the
action execution specification be the parent? And if so, what does this
mean?
TIA
Joost
Re: model validation problem sequence diagram [message #1060605 is a reply to message #1060567] Mon, 27 May 2013 05:38 Go to previous message
Hi Marc-Florian,
> Hi Joost,
> solved!
mean?
TIA
Joost
Previous Topic:Why is a (member)function not an action or activity?
Next Topic:Adding new buttons in Papyrus Palette
Current Time: Fri Jul 25 06:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.07284 seconds
