Home » Modeling » OCL » [OCLinEcore] Load complete OCL resource not always working as expected
[OCLinEcore] Load complete OCL resource not always working as expected [message #1060328] Fri, 24 May 2013 03:36 Go to next message
I have an EMF domain model (written with the OCLinEcore editor) and a OCL file containing additional validation rules for the model.
In my runtime Eclipse, I create an instance of my domain model (via a GMF based editor) and wants to validate it using the external OCL file. When I right-click on the diagram, the "Load Complete OCL Resource" action appears correctly but it doesn't seem to do anything (my validation rules are not invoked, since I added a rule that always fails but no error shows up).
I installed version 4.1.0.RC1.
This seems to fail on Kepler but I've been able to have it working on Juno. However, I tried now again with a fresh install of Juno and I have the same problem. I can't say what exactly triggers the problem unfortunately...
Did you experience something similar or have any idea what might be the problem ?
Thanks for the help,
Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060341 is a reply to message #1060328] Fri, 24 May 2013 04:26 Go to previous messageGo to next message
Does the error log show anything.
RC1 has an improved PopUP diagnostic if Load fails, buit othewuse little
change.
Can you provide a Zipped project that fails?
Ed Willink
On 24/05/2013 08:36, Cedric Moonen wrote:
> Hello,
> OCL file containing additional validation rules for the model. In my
> unfortunately...
> the problem ?
> Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060345 is a reply to message #1060341] Fri, 24 May 2013 04:44 Go to previous messageGo to next message
Hi Ed,
No, the error log doesn't show anything.
I don't think that sending you the project will solve anything, since it was working properly for me with another eclipse installation (I had to reinstall Eclipse and since then I experienced the problem). So, I guess this is a tooling issue (some plug-ins that are not installed and that should be installed maybe).
Anyway, I'll send you the files via mail (for confidentiality reasons).
Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060475 is a reply to message #1060345] Sat, 25 May 2013 02:20 Go to previous messageGo to next message
Thanks. I see the problem. It looks as if the Complete OCL tutorial
should fail too, which begs the question as to why no JUnit test fails....
Ed Willink
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060678 is a reply to message #1060475] Mon, 27 May 2013 12:53 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=409169 for details.
Hopefully it's fixed now (in Kepler RC2).
Ed Willink
On 25/05/2013 07:20, Ed Willink wrote:
> Hi
> fails....
> Regards
> Ed Willink
Previous Topic:Load Complete OCL Resource Automatically
Next Topic:[Announce] Eclipse OCL 4.1.0 (Kepler) RC2 is available.
Current Time: Sat Jul 26 11:36:41 EDT 2025
Powered by FUDForum. Page generated in 0.05149 seconds
