Home » Language IDEs » PHP Development Tools (PDT) » a collection of PDT errors on Eclipse Classic 4.2.2
a collection of PDT errors on Eclipse Classic 4.2.2 [message #1057985] Fri, 10 May 2013 06:46 Go to next message
I've recently started writing some PHP code at home on Eclipse 4.2 and I've noticed that the PHP Development Tools plugin seems to be outdated and doesn't work well with my Eclipse version.
I've received these and more errors in the error log:
1)
Help index declared, but missing for plugin org.eclipse.php.help.
(no stacktrace)
2)
Conflicting handlers for org.eclipse.wst.sse.ui.toggle.comment: {org.eclipse.php.internal.ui.actions.PHPToggleLineCommentHandler@160277c} vs {org.eclipse.wst.sse.ui.internal.handlers.ToggleLineCommentHandler@1c072e9}
This one pops up very frequently when editing a PHP file.
3)
offset 16039 is out of [0, 119]
org.eclipse.jface.text.BadLocationException: offset 16039 is out of [0, 119]
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.checkBadLocation(PhpTokenContainer.java:453)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.getToken(PhpTokenContainer.java:59)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpTokenContainer.getTokens(PhpTokenContainer.java:105)
at org.eclipse.php.internal.core.documentModel.parser.regions.PhpScriptRegion.getPhpTokens(PhpScriptRegion.java:105)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.lineContainIncompleteBlock(DefaultIndentationStrategy.java:486)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.isIndentationBase(DefaultIndentationStrategy.java:323)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.getIndentationBaseLine(DefaultIndentationStrategy.java:110)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.placeMatchingBlanksForStructuredDocument(DefaultIndentationStrategy.java:636)
at org.eclipse.php.internal.core.format.DefaultIndentationStrategy.placeMatchingBlanks(DefaultIndentationStrategy.java:565)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.placeMatchingBlanks(IndentLineAutoEditStrategy.java:190)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.autoIndentAfterNewLine(IndentLineAutoEditStrategy.java:58)
at org.eclipse.php.internal.ui.autoEdit.IndentLineAutoEditStrategy.customizeDocumentCommand(IndentLineAutoEditStrategy.java:124)
at org.eclipse.php.internal.ui.autoEdit.MainAutoEditStrategy.customizeDocumentCommand(MainAutoEditStrategy.java:64)
at org.eclipse.jface.text.TextViewer.customizeDocumentCommand(TextViewer.java:3779)
at org.eclipse.jface.text.TextViewer.handleVerifyEvent(TextViewer.java:3816)
at org.eclipse.jface.text.source.projection.ProjectionViewer.handleVerifyEvent(ProjectionViewer.java:1276)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.handleVerifyEvent(StructuredTextViewer.java:761)
at org.eclipse.jface.text.TextViewer$TextVerifyListener.verifyText(TextViewer.java:435)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:273)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.java:7146)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.java:8007)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java:2467)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java:5907)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.java:5937)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.java:5629)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1521)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
4)
Unhandled event loop exception
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.compareRulerLine(PHPStructuredTextAnnotationHover.java:159)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.getMarkerMessages(PHPStructuredTextAnnotationHover.java:307)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextAnnotationHover.getHoverInfo(PHPStructuredTextAnnotationHover.java:239)
at org.eclipse.jface.text.source.AnnotationBarHoverManager.computeInformation(AnnotationBarHoverManager.java:385)
at org.eclipse.jface.text.AbstractInformationControlManager.doShowInformation(AbstractInformationControlManager.java:1131)
at org.eclipse.jface.text.AbstractHoverInformationControlManager$MouseTracker.mouseHover(AbstractHoverInformationControlManager.java:519)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:208)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
Have any of these errors been resolved in the latest commits to the PDT repository, and if yes, how could I get a build of the latest sources? It seems building Eclipse plugins isn't straightforward and I only need this one plugin, so wasting the time to learn how to do that might not be worth it.
[Updated on: Fri, 10 May 2013 06:47] by Moderator
Re: a collection of PDT errors on Eclipse Classic 4.2.2 [message #1060458 is a reply to message #1057985] Fri, 24 May 2013 15:13 Go to previous message
Hey Juris, did you ever manage to figure this issue out? I'm having the exact same problem on a new machine I'm setting up.
[Updated on: Fri, 24 May 2013 15:13] by Moderator
Previous Topic:Alternative to Eclipse PDT... too slow
Next Topic:Linking eclipse simulator and FORTRAN language
Current Time: Sat Jul 26 07:58:02 EDT 2025
Powered by FUDForum. Page generated in 0.05843 seconds
