Home » Modeling » GMF (Graphical Modeling Framework) » Connector Labels (Polyline Connection)(PolylineConnection , Connector Label)
Connector Labels (Polyline Connection) [message #1059231] Fri, 17 May 2013 08:18 Go to next message
In one diagram I have a figure element that is the representation of a Polyline and for it I attached a label with a text. The Label is the one that you can show/hide in the diagram view by Show/Hide Connector Labels. When the text that goes to the Label becomes long, I need to make it multiple line or have it multiple line from the beginning. I tried to change the type from a Label to a Custom Figure and set the CustomAttribute textWrap to true , but not possible to see this happening the moment the Label is displayed in the Diagram Editor.
Any idea is welcome.
Re: Connector Labels (Polyline Connection) [message #1060445 is a reply to message #1059231] Fri, 24 May 2013 12:56 Go to previous messageGo to next message
Hi Dan,
your generated EditPart has most likely an underlying "WrappingLabel" as its figure, which has the
setTextWrap(...)
implemented by default.
Make sure, when you perform the actual editing on the label to use CTRL+Enter to insert a linebreak, as only enter will commit the currently edited text.
Thomas
Re: Connector Labels (Polyline Connection) [message #1061384 is a reply to message #1060445] Fri, 31 May 2013 08:13 Go to previous messageGo to next message
Hi Thomas,
I know that setTextWrap could do the trick. Just to make the picture more detailed:
- I have this text for the label taken from two other properties, based on the user selection of a flag. So I am extracting the text to be displayed like this:
public String getUsedGuard()
if(this.isRuleFromGrammar == true){if(basicGetGuardRuleName() != null)
return basicGetGuardRuleName().getRuleName();
else
return "";
else{
return this.getGuard();
So finally I will have a string that will populate the label. So the label is not edited directly in the view, but managed through other properties. This is why I am searching another way of forcing the label to have itself more lines and to manage the text that comes within.
Re: Connector Labels (Polyline Connection) [message #1816105 is a reply to message #1061384] Mon, 21 October 2019 06:15 Go to previous message
Hi Thomas,
Can you share the sample code for adding the label to the polyline figure?
Should we add the label as a child to a polyline figure?
Previous Topic:DocumentProvider::createElementInfo does not handle IFileEditorInput
Next Topic:Opening properties view on clicking on any figure in canvas
Current Time: Sat Jul 26 19:05:14 EDT 2025
Powered by FUDForum. Page generated in 0.45250 seconds
