Home » Language IDEs » Java Development Tools (JDT) » Reflective Access to @NonNull
Reflective Access to @NonNull [message #1060365] Fri, 24 May 2013 06:07 Go to next message
I'm trying to determine if a method has an @NonNull return
I would expect to just do
myMethod.getAnnotation(NonNull.class)
but the return is always null even though org.eclipse.jdt.annotation is
on the class path and the method has an @NonNull annotation.
Is there some magic command line option to activate annotations within a
JUnit launch?
Is there some magic command line option to avoid annotations being
stripped out somewhere?
[I've exported org.eclipse.jdt.annotation from the plugin containing the
annotated method.]
Ed Willink
Re: Reflective Access to @NonNull [message #1060419 is a reply to message #1060365] Fri, 24 May 2013 10:48 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 24 May 2013 10:56] by Moderator
Re: Reflective Access to @NonNull [message #1060420 is a reply to message #1060419] Fri, 24 May 2013 10:49 Go to previous messageGo to next message
No Message Body
Re: Reflective Access to @NonNull [message #1060421 is a reply to message #1060420] Fri, 24 May 2013 10:53 Go to previous messageGo to next message
[Wow - serious browser issues - sorry about the incomplete responses above....]
The RetentionPolicy for @NonNull is CLASS (as opposed to SOURCE or RUNTIME); which means the annotation is available for the compiler (either via the source file, obviously, or the class file), but the annotation is not loaded by the JVM and available at runtime via reflection.
Re: Reflective Access to @NonNull [message #1060443 is a reply to message #1060421] Fri, 24 May 2013 12:26 Go to previous messageGo to next message
Right, @NonNull is not available at runtime.
The reason being: people want to be able to run the code without linking the annotation library. Makes sense?
If the JUnit has access to the class files it could, however, use your favorite bytecode library (BCEL, ASM, ...) to retrieve the annotation from there. Would that be feasible for your case?
Re: Reflective Access to @NonNull [message #1060446 is a reply to message #1060443] Fri, 24 May 2013 12:59 Go to previous message
Thanks for the explanation.
At one level I agree, at another, I regard @NonNull as part of the type
system and so it should be available just like the rest of it.
I have no favourite bytecode library. Never used any of them. Can you
recommend one that is in Orbit or better?
org.objectweb.asm?
org.apache.xbean.asm?
org.apache.bcel?
Any short cuts to a cookbook example just like
myMethod.getAnnotation(NonNull.class)?
FYI. My OCL to Java codegen plugin generates Java code with annotations
that indicate the internal non-null and non-invalid analysis. However
the CG analysis knows more than Java and so spurious warnings need to be
suppressed by auto-generating @suppressWarnings("null").
Ed Willink
Previous Topic:Could not connect to New MySQL.
Next Topic:Issue with Extension point for action
Current Time: Sun Jul 27 03:55:49 EDT 2025
Powered by FUDForum. Page generated in 0.05946 seconds
