Home » Eclipse Projects » Remote Application Platform (RAP) » RAP in standalone OSGi javax.servlet import constraint(Problems running RAP in standalone OSGi)
RAP in standalone OSGi javax.servlet import constraint [message #1060370] |
Fri, 24 May 2013 06:31  |
As a unit-test environment I was hoping to be able to configure a very simple OSGI environment to test my RAP (and TABRIS) applications. However, I'm running into a problem where javax.servlet cannot be satisfied.
I know similar issues have been posted numerous times in the past, but none of them seem to directly address the situation I'm facing, so I wonder if someone could point me in the right direction... I'm sure it is something simple to fix...
Firstly, here is the output from the OSGI console, which I'm launching from a Command Prompt in Windows:
osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20130305-2200
Fragments=36
1 ACTIVE com.ibm.icu.base_50.1.0.v20121116-2
2 INSTALLED iet.co.uk.rapide.RAP_85.80.0
3 ACTIVE javax.xml_1.3.4.v201005080400
4 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
5 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
6 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
7 ACTIVE org.eclipse.core.commands_3.6.100.v20130220-2151
8 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130221-0103
9 ACTIVE org.eclipse.core.databinding_1.4.1.v20130220-2151
10 ACTIVE org.eclipse.core.databinding.beans_1.2.200.v20130220-2151
11 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130220-2151
12 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130220-2151
13 ACTIVE org.eclipse.core.expressions_3.4.500.v20130221-0103
14 ACTIVE org.eclipse.core.jobs_3.5.300.v20130221-0103
15 ACTIVE org.eclipse.core.runtime_3.9.0.v20130221-0103
16 ACTIVE org.eclipse.equinox.app_1.3.100.v20130225-1702
17 ACTIVE org.eclipse.equinox.common_3.6.100.v20130225-1702
18 ACTIVE org.eclipse.equinox.console_1.0.100.v20130225-1702
19 INSTALLED org.eclipse.equinox.http.registry_1.1.200.v20130225-1702
20 INSTALLED org.eclipse.equinox.http.servlet_1.1.300.v20130225-1702
21 INSTALLED org.eclipse.equinox.http.servletbridge_1.0.300.v20130225-1702
22 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20130225-1702
23 ACTIVE org.eclipse.equinox.registry_3.5.300.v20130225-1702
24 INSTALLED org.eclipse.equinox.servletbridge_1.2.200.v20130225-1702
25 ACTIVE org.eclipse.equinox.util_1.0.400.v20130307-2007
26 ACTIVE org.eclipse.help_3.6.0.v20130221-0120
27 ACTIVE org.eclipse.osgi.services_3.3.100.v20130225-1645
28 INSTALLED org.eclipse.rap.clientscripting_0.1.100.201305241038
29 INSTALLED org.eclipse.rap.jface_2.1.0.20130225-1108
30 INSTALLED org.eclipse.rap.jface.databinding_2.1.0.20130220-2001
31 INSTALLED org.eclipse.rap.rwt_2.1.0.20130410-0853
32 INSTALLED org.eclipse.rap.rwt.osgi_2.1.0.20130220-2001
33 INSTALLED org.eclipse.rap.ui_2.1.0.20130220-2001
34 INSTALLED org.eclipse.rap.ui.forms_2.1.0.20130306-1637
35 INSTALLED org.eclipse.rap.ui.views_2.1.0.20130220-2001
36 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.2.100.v20120522-2049
Master=0
37 INSTALLED org.eclipse.rap.ui.workbench_2.1.0.20130225-1531
osgi> start 31
gogo: BundleException: The bundle "org.eclipse.rap.rwt_2.1.0.20130410-0853 [31]" could not be resolved. Reason: Missing Constraint:
Import-Package: javax.servlet; version="[2.3.0,4.0.0)"
osgi>
As you can see, then explicit start of bundle 31 (rap.rwt) is failing because of javax.servlet. Various other issues, but this is the root issue I think.
Now, I've got org.eclipse.equinox.servletbridge.extensionbundle included as a Bundle, which you can see at Bundle/Fragment 36 as RESOLVED. I believe this is correct, as the extensionbundle is a Fragment, so cannot be started as such?
extensionbundle exports javax.servlet, in this case with a version of "2.5", as you can see from the manifest within it:
X-Deploy-Export-Package: javax.servlet;version="2.5",javax.servlet.htt
p;version ="2.5",javax.servlet.resources;version="2.5",org.eclipse.eq
uinox.servletbridge;version="1.1"
So, why can't I start rap.rwt's bundle? Why can it not find javax.servlet?
Final piece of information... here is the config.ini from the configuration subdirectory below where I'm starting OSGI:
#Product Runtime Configuration File
osgi.bundles.defaultStartLevel=4
osgi.console=9090
osgi.console.enable.builtin=false
osgi.bundles=com.ibm.icu.base@start,\
iet.co.uk.rapide.RAP@start,\
javax.xml@start,\
org.apache.felix.gogo.command@start,\
org.apache.felix.gogo.runtime@start,\
org.apache.felix.gogo.shell@start,\
org.eclipse.core.commands@start,\
org.eclipse.core.contenttype@start,\
org.eclipse.core.databinding@start,\
org.eclipse.core.databinding.beans@start,\
org.eclipse.core.databinding.observable@start,\
org.eclipse.core.databinding.property@start,\
org.eclipse.core.expressions@start,\
org.eclipse.core.jobs@start,\
org.eclipse.core.runtime@start,\
org.eclipse.equinox.app@start,\
org.eclipse.equinox.common@start,\
org.eclipse.equinox.console@start,\
org.eclipse.equinox.http.registry@start,\
org.eclipse.equinox.http.servlet@start,\
org.eclipse.equinox.http.servletbridge@start,\
org.eclipse.equinox.preferences@start,\
org.eclipse.equinox.registry@start,\
org.eclipse.equinox.servletbridge@start,\
org.eclipse.equinox.util@start,\
org.eclipse.help@start,\
org.eclipse.osgi.services@start,\
org.eclipse.rap.clientscripting@start,\
org.eclipse.rap.jface@start,\
org.eclipse.rap.jface.databinding@start,\
org.eclipse.rap.rwt@start,\
org.eclipse.rap.rwt.osgi@start,\
org.eclipse.rap.ui@start,\
org.eclipse.rap.ui.forms@start,\
org.eclipse.rap.ui.views@start,\
org.eclipse.equinox.servletbridge.extensionbundle,\
org.eclipse.rap.ui.workbench@start
Thanks, John
Re: RAP in standalone OSGi javax.servlet import constraint [message #1061207 is a reply to message #1060426] |
Thu, 30 May 2013 10:19   |
Thanks Ralf,
So, I removed the servlet extension bundle, and added in javax.servlet, and this resolved the import problem and allowed all bundles to start up.
However, I'm not sure if my bundle is available, and if so, how do I connect to it's entry point?
By the way, I've moved on to Tabris for the time-being, but I assume the principle is the same.
Here is my latest attempt:
config.ini:
osgi.bundles=com.eclipsesource.tabris@start,\
iet.co.uk.rapide.TABRIS@start,\
javax.servlet@start
Console output, showing ss results (all bundles ACTIVE):
osgi> ss
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20130513-1345
1 ACTIVE com.eclipsesource.tabris_1.1.0.201305301409
2 ACTIVE iet.co.uk.rapide.TABRIS_85.80.0
3 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
4 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
5 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
6 ACTIVE org.eclipse.core.commands_3.6.100.v20130515-1857
7 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
8 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
9 ACTIVE org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354
10 ACTIVE org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-1442
11 ACTIVE org.eclipse.equinox.servletbridge_1.2.300.v20130508-1243
12 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
13 ACTIVE org.eclipse.rap.jface_2.1.0.20130506-1748
14 ACTIVE org.eclipse.rap.rwt_2.1.0.20130520-1326
15 ACTIVE org.eclipse.rap.rwt.osgi_2.1.0.20130506-1748
16 ACTIVE org.eclipse.rap.clientscripting_0.1.100.201305301409
17 ACTIVE javax.servlet_3.0.0.v201112011016
osgi>
Log file within configuration folder:
!SESSION 2013-05-30 15:03:06.424 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_22
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -clean -console
!ENTRY org.eclipse.osgi 4 0 2013-05-30 15:03:07.182
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.core.runtime.adaptor.EclipseStarter.main(EclipseStarter.java:152)
I can see there are reported issues above, but am loathed to add the eclipse bundles in, as I cannot see why they would genuinely be required, and the knock-on chain is quite long!
In my 'rapide' bundle is my application's Entry Point, defined by its manifest with an appropriate Activator. I know the code is correct because I'm able to use this within a WAR in WebLogic (for example).
Here is my jar's manifest:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %Bundle-Name
Bundle-SymbolicName: iet.co.uk.rapide.TABRIS;singleton:=true
Bundle-Version: 85.80.0
Bundle-Vendor: %Bundle-Vendor
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: uk.co.iet.rapide
Bundle-ClassPath: .,WEB-INF/lib/gen80rt.jar,WEB-INF/lib/jna.jar
Import-Package: org.eclipse.jface.fieldassist,org.eclipse.jface.layout,org.eclipse.osgi.baseadaptor.bundlefile,org.eclipse.rap.clientscripting
Bundle-Activator: uk.co.iet.rapide.tabris.Activator
Require-Bundle: org.eclipse.rap.rwt;bundle-version="2.0.0",org.eclipse.osgi,com.eclipsesource.tabris;bundle-version="1.0.0",javax.servlet;bundle-version="3.0.0"
Bundle-ClassPath:
,WEB-INF/Demo/resources.jar
,WEB-INF/Demo/rapide_strings.jar
,WEB-INF/Demo/DEMO.jar
,WEB-INF/Demo/MOBDEMO.jar
I tried the above manifest with and without the javax.servlet bundle dependency, which didn't appear to have any effect either way.
I expected to be able to access my application from a browser with url:
"http://127.0.0.1:9090/demo" where 'demo' is my Entry Point, but I'm unsure where to specify the port (which could simply be the only problem I'm left with!). If I specify "-console 9090" when starting OSGi, I get no console (so cannot use 'ss' for example), and my web browser (Chrome in this case), thinks I'm trying to download a file with the above URL.
So, all in all, I'm getting a bit confused, so would appreciate further pointers if you are able!
Many thanks, John
Re: RAP in standalone OSGi javax.servlet import constraint [message #1061223 is a reply to message #1061207] |
Thu, 30 May 2013 11:16   |
Ok, been bashing away experimenting further and have got it 'sort of' working...
Here's my config.ini with JETTY added, which I think was the primary source of my problems:
org.eclipse.equinox.http.jetty@start,\
org.eclipse.jetty.http@start,\
org.eclipse.jetty.io@start,\
org.eclipse.jetty.util@start,\
org.eclipse.jetty.server@start,\
org.eclipse.jetty.continuation@start,\
org.eclipse.jetty.servlet@start,\
org.eclipse.jetty.security@start,\
javax.servlet@start
Now the problem I have is that Jetty is starting to listen on default port 80, which is no good for me, as I also have IIS on my workstation. I'd like to use port 9090, but where do I specify this?
Almost there!!
Thanks, John
Current Time: Wed Jul 23 11:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.14222 seconds
