Home » Modeling » TMF (Xtext) » XtextEditor manipulation(Adding/Editing some functionality to the XtextEditor)
XtextEditor manipulation [message #1059996] Wed, 22 May 2013 09:30 Go to next message
Hello everyone,
could someone help me with the following problem, please:
I want to be able when I'm pressing in a view (like the outline) on a object from my model to be able to show in the editor only that element + subelements and the rest of the things in the editor I would like to have them collapsed or grayed.
Something like this:
View:
Red
Blue
Black
and if I click on Red in the editor should show me:
+myLanguage
Red name id
 subelementOfRed name id
 subelement2OfRed id
+code
Red name id
+code
the + is for collapse code
More info: now I have the XtextEditor and the IXtextDocument, I got also the model from : IXTextDocument.readOnly(new IUnitOfWork<Object, XtextResource>()).
But I'm a little stuck of how should I make this thing to collapse in between (I get the right elements from the model)
Thanks in advance!
Re: XtextEditor manipulation [message #1060017 is a reply to message #1059996] Wed, 22 May 2013 10:32 Go to previous messageGo to next message
I did some foldig customizations in a project. The corresponding code is in the folding package and the TerminologyXtextEditor (just as inspiration for how to collapse regions).
You will have to solve the following problems:
* identify the folding regions that correspond to the outline view selection
* find a good hook for your selection change in the view (OutlineWithEditorLinker?), where you collapse/expand the regions
A very hacky (but possibly minimal effort) idea if there was a 1:1 correspondence between outline element and text element (which seems not to be your use case).
When you select an element in the outline view, the corresponding model element is expanded automatically, so you could simply collapse *all* regions first.
Alex
Re: XtextEditor manipulation [message #1060027 is a reply to message #1060017] Wed, 22 May 2013 11:01 Go to previous messageGo to next message
Thanks for the quick answer.
I will look into it, but first I have another question, because I already did something in another way.
I used the ISourceViewer sourceViewer to show only what I'm interested and it works, but now I have only the problem that if I have more elements (at different offsets) will take only my last element with the function: sourceViewer.setVisibleRegion(offset, length); can I somehow make more regions visible in the same time ?
This will resolve my problem faster Smile.
Re: XtextEditor manipulation [message #1060091 is a reply to message #1060027] Thu, 23 May 2013 02:09 Go to previous messageGo to next message
A projection source viewer is a source viewer which supports multiple visible regions which can dynamically be changed.
(Projection Viewer Java Doc)
So I guess, folding is the way to show more than one region at a time.
Alex
Re: XtextEditor manipulation [message #1060237 is a reply to message #1060091] Thu, 23 May 2013 12:13 Go to previous messageGo to next message
Is there a nice way to get the offset in the xtexteditor when you have the EMF object from the state ( IXTextDocument.readOnly(new IUnitOfWork<Object, XtextResource>())) ?
Re: XtextEditor manipulation [message #1060264 is a reply to message #1060237] Thu, 23 May 2013 13:35 Go to previous messageGo to next message
use NodeModelUtils.
Alex
Re: XtextEditor manipulation [message #1060336 is a reply to message #1060264] Fri, 24 May 2013 04:13 Go to previous messageGo to next message
This is so perfect, thanks a lot!
Re: XtextEditor manipulation [message #1063699 is a reply to message #1060264] Thu, 13 June 2013 14:52 Go to previous messageGo to next message
Hi Alex,
Now I am doing something like
ICompositeNode node = NodeModelUtils.findActualNodeFor(findP);//NodeModelUtils.getNode(findP);
								sourceViewer.setVisibleRegion(node.getOffset(), node.getLength());
works fine, but I have only one problem.
When I have something that is optional in my grammar for ex:
'car'  (model=STRING (color=STRING)?)
if I'm using: car Audi works just fine, but if now I want to add the color Red to it the node will have the same length as when was only without the color.
The model is updated (saw it in debug).
Could you help me please?
Thanks in advance
Re: XtextEditor manipulation [message #1063750 is a reply to message #1063699] Fri, 14 June 2013 02:09 Go to previous messageGo to next message
when adding the color, is the code setting the visible region invoked at all? Have you checked that the color is set in the findP variable?
Alex
Re: XtextEditor manipulation [message #1063770 is a reply to message #1063750] Fri, 14 June 2013 03:57 Go to previous messageGo to next message
yes is added, as I said I check with debug and is added in findP.
When I write:
car Audi
4 wheels
- the visible part is the whole object car Audi 4 wheels
works fine
but when I add the color to this and then I have
car Audi "Red"
4 wheels
- the visible part is car Audi "Red" 4 - so this mean that the length of the string "Red" (+"") is 5 + 1 ws = 6 which is the length of the wheels (6) so will not show me the wheels in my code.
I think the problem of the node is that doesn't compute the length when you add the new feature.
As in my example the 'color' at start was null, but when I decided to update/add the color the length didn't add the new string.
Hope now is clear.
Thanks!
Re: XtextEditor manipulation [message #1063799 is a reply to message #1063770] Fri, 14 June 2013 05:37 Go to previous messageGo to next message
it is not quite clear to me, because what you are saying is: the semantic model (findP) and the node model attached to it (node) are out of synch, although reparsing must have happened (otherwise the color feature would not be set). I have never experienced this problem. What does node.getText() look like?
Alex
Re: XtextEditor manipulation [message #1063855 is a reply to message #1063799] Fri, 14 June 2013 10:00 Go to previous messageGo to next message
Hi again,
So the node.getText() shows what I need/expected the whole text
car Audi "Red"
4 wheels
but in the editor appears:
car Audi "Red"
4
I have the breakpoint at this line: sourceViewer.setVisibleRegion(node.getOffset(), node.getLength());
Thanks!
Re: XtextEditor manipulation [message #1065216 is a reply to message #1063855] Mon, 24 June 2013 16:02 Go to previous message
so no idea what can this be ?
Previous Topic:JvmModelInferrer and code generation
Next Topic:Read Xtext resource as EMF resource
Current Time: Sun Jul 27 11:31:18 EDT 2025
Powered by FUDForum. Page generated in 0.11996 seconds
