Home » Modeling » EMF » [Teneo] Default Value in DDL Generation([Teneo] Default Value in DDL Generation)
[Teneo] Default Value in DDL Generation [message #1059941] Wed, 22 May 2013 05:09 Go to next message
Hi all,
I want to add a not null column to a table generated via Teneo from my ECore model.
Is there any possibility to set a default value for this column during DDL generation of teneo?
Somthing like below
ALTER TABLE [Employees] ADD DEFAULT ("SP") FOR [Department]
I cannot use annotations in entity classes as I am using dynamic entities.
Thanks and Regards,
Minu Martin
Re: [Teneo] Default Value in DDL Generation [message #1060176 is a reply to message #1059941] Thu, 23 May 2013 08:03 Go to previous messageGo to next message
Hi Minu,
I see that hbm indeed supports a sql expression for default but that it is not part of the Teneo supported annotations.
Can you enter a bugzilla for it?
Another approach is to set the default in the ecore efeature, this will be applied when creating new objects.
gr. Martin
On 05/22/2013 02:36 PM, Minu martin wrote:
> Hi all,
> Somthing like below
> Thanks and Regards,
> Minu Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Default Value in DDL Generation [message #1060565 is a reply to message #1060176] Mon, 27 May 2013 01:35 Go to previous message
Hi Martin,
Thanks for the reply.
I have created a bugzilla for this - Bug 409104.
Please take a look into this.
I am not using generated ecore objects. So I cannot use the second option you suggested.
Thanks & Regards,
Minu Martin
Previous Topic:[XCore] Compiler overrides code tagged as not generated
Next Topic:[CDO] Understanding proxy state.
Current Time: Wed Jul 30 17:09:49 EDT 2025
Powered by FUDForum. Page generated in 0.04014 seconds
