Home » Modeling » EMF » [CDO] Clearing a CDOResource content which has a Proxy object
[CDO] Clearing a CDOResource content which has a Proxy object [message #1059281] |
Fri, 17 May 2013 06:46  |
I have a CDOResource, which has an object in it's content looking like
this: (Copy paste from Variable View).
eObject $Proxy23 (id=5790)
'eObject' referenced from:
h org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2$1 (id=5792)
'h' referenced from:
this$1 org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2 (id=333)
val$source
com.netxforge.netxstudio.scheduling.impl.JobRunContainerImpl (id=5795)
val$target
org.eclipse.emf.cdo.internal.common.id.CDOIDObjectLongImpl (id=5796)
val$type org.eclipse.emf.ecore.impl.EClassImpl (id=338)
So apparently the referenced object was not resolved from the target.
(JobRunContainer).
How can I detect a stale reference? I have tried using
CDOUtil.isStaleObject(..) but it's negative on the referenced object. (I
can actually get the object with an exception).
But when I clear the contents, I get an exception:
I clean the list like this: (As you might notice, I call retainAll()
which calls indexOf(..)
I can get the same exception with contents.indexOf(Object).
| QuartzScheduler_Worker-2 | 2013-05-17 12:39:08.575 |
com.netxforge.netxstudio.server.job | /trace.jobs |
com.netxforge.netxstudio.server.job.NetxForgeJob | execute | 127 | Error
instantiating job: class
com.netxforge.netxstudio.scheduling.impl.MetricSourceJobImpl |
org.eclipse.emf.cdo.util.ObjectNotFoundException: Object OID21459772 not
found
at
org.eclipse.emf.cdo.view.CDOStaleReferencePolicy$2$1.invoke(CDOStaleReferencePolicy.java:101)
at $Proxy23.equals(Unknown Source)
at java.util.ArrayList.indexOf(ArrayList.java:269)
at java.util.ArrayList.contains(ArrayList.java:252)
at
org.eclipse.emf.common.util.DelegatingEList.retainAll(DelegatingEList.java:579)
at
com.netxforge.netxstudio.server.job.NetxForgeJob.addAndTruncate(NetxForgeJob.java:236)
at
com.netxforge.netxstudio.server.job.NetxForgeJob.createWorkFlowMonitor(NetxForgeJob.java:146)
at
com.netxforge.netxstudio.server.job.NetxForgeJob.execute(NetxForgeJob.java:115)
at org.quartz.core.JobRunShell.run(JobRunShell.java:206)
at
org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:548)
Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1059771 is a reply to message #1059359] |
Tue, 21 May 2013 10:36   |
On 17-05-13 18:11, Eike Stepper wrote:
> Am 17.05.2013 12:46, schrieb Christophe Bouhier:
>> Hi,
>> (id=333)
>> val$source
>> val$target
>> (JobRunContainer).
>> (I can actually get the object with an exception).
> What does CDOUtil.isStaleObject(..) return for that object (the one that
> you can get without an exception)? Can you provide me with a small test
> case to reproduce it?
> You can also compare with
> Bugzilla_279982_Test.testBugzilla_279982_Single().
Thanks Eike, will check this test case.
>> Error instantiating job: class
>> not found
>> at
> Hm, we could let the proxy handle calls to equals() such that "arg0 ==
> this", instead of throwing an ObjectNotFoundException. Please submit an
> enhancement request.
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> at
>> at
>> at
>> at
>> at
>> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060102 is a reply to message #1059771] |
Thu, 23 May 2013 02:54   |
Dear Christophe,
Sorry for posting this question here.
I need to manage palette in papyrus programmatically when user is working on the diagram editor. When I select an element in the diagram editor, I need to refresh the palette. So I want to be able to add/remove some entries or set them as visible or invisible on the palette.
I found your reply to Dave posted in July 2009 about changing palette icons. You mentioned that its possible to access to paletteRoot through the editor: XXXDiagramEditor.getEditDomain().getpaletteViewer().getpaletteRoot()
Is the paletteRoot what I need for this case?
I traced the code and I guess the XXXDiagramEditor is UMLDiagramEditor. But the problem is that I don't know how to access to the UMLDiagramEditor:( can you please guide me?
Thanks and regards,
Leila
Christophe Bouhier wrote on Tue, 21 May 2013 10:36On 17-05-13 18:11, Eike Stepper wrote:
>> Hi,
>> (id=333)
>> val$source
>> val$target
>> (JobRunContainer).
>> not found
>> at
> Cheers
> /Eike
>> at
>> at
>> at
>> at
>> at
>> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060127 is a reply to message #1060102] |
Thu, 23 May 2013 04:27   |
Am 23.05.2013 08:54, schrieb Leila A:
> Dear Christophe,
> Is the paletteRoot what I need for this case? I traced the code and I guess the XXXDiagramEditor is UMLDiagramEditor.
How's that related to CDO?
Cheers
/Eike
> Thanks and regards,
> Leila
>> >> Hi,
>> >> (id=333)
>> >> val$source
>> >> val$target
>> >> (JobRunContainer).
>> >> not found
>> >> at
>> > Cheers
>> > /Eike
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> Thanks! Christophe
Re: [CDO] Clearing a CDOResource content which has a Proxy object [message #1060136 is a reply to message #1060102] |
Thu, 23 May 2013 05:28  |
On 23-05-13 08:54, Leila A wrote:
> Dear Christophe,
I think it's better to mail them directly, if you need someone's
specific attention. Many people watching this forum will frown reading a
question about GMF/GEF here. Please mail me directly or on the GMF
forum, I will try to find the answer for you.
> the editor:
> guide me?
> Thanks and regards,
> Leila
>> >> Hi,
>> (id=5792)
>> >> (id=333)
>> >> val$source
>> >> val$target
>> >> (JobRunContainer).
>> that
>> >> not found
>> >> at
>> > Cheers
>> > /Eike
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> Thanks! Christophe
Current Time: Wed Jul 23 12:05:36 EDT 2025
Powered by FUDForum. Page generated in 0.19565 seconds
