SOLVED:Timeout received before confirming the posted event [message #1043930] |
Thu, 18 April 2013 05:30  |
I use jubula of 1.3.0,when jubula take the action of "replace text of Cell" and "Key Combination",it always occurs the Error "Timeout received before confirming the posted event".
Could This Problem be solved?
Best wishes,
Posia
[Updated on: Sat, 08 June 2013 05:18] by Moderator
Re: Timeout received before confirming the posted event [message #1236947 is a reply to message #1061951] |
Tue, 28 January 2014 08:18   |
Hallo all,
I have the same problem with timeout. because I made the test cases on a very fast PC(RAM 8GB, Processor: i7,3,4 GHZ), but I wanna to run these test cases on other PC(RAM 2GB, Processor:intel quade core 2,4 GHZ) with less speed, then always comes this error of time out(Error Description:Timeout received before confirming the posted event)
I have read your comments but I have no idea about GD_IGNORE_TIMEOUT=true, what is that?
From where can I configure this value to ignore the error message of timeout.
Thank you alot.
Louis
Re: SOLVED:Timeout received before confirming the posted event [message #1725966 is a reply to message #1043930] |
Tue, 08 March 2016 11:39  |
I'm having the same problem. I'm running tests remotely ($ jubula_8.2.0.021/jubula/testexec -testsuite MySuite -dburl jdbc:mysql://db.mydbserver.org:3306/MyTestDB -project MyProject -language en_US -version 1.0 -dbuser MyUser -dbpw MyUserPassword -port 60000 -resultdir /path/to/results -autconfig MyAUTConfig -server my.virtual.machine)
This problem occurs quite randomly but constantly.
In the attached images you can see how the timeout occurred on an active and 100% found object causing the click - CAP to fail.
Since I'm running an executable program, looks like there is no way to pass argument to the jvm (-DGD_IGNORE_TIMEOUT=true).
So, it's there another way to disable or adjust the timeout?
Thank you.
Luca
FUDForum. Page generated in 0.28170 seconds
