getLineNumber [message #1059833] |
Tue, 21 May 2013 15:30  |
I am using the org.eclipse.php.internal.core for parsing PHP code. Here is a small test php file to pars:
<?php
$name = 'Elijah';
$yearBorn = 1975;
$currentYear = 2005;
$age = $currentYear - $yearBorn;
To get the line number I do as following
public class FactExtractorVisitor implements Visitor {
public boolean visit(Program node) {
// TODO Auto-generated method stub
this.root=node;
return true;
public boolean visit(Variable node) {
System.out.println(node.toString());
System.out.println(this.root.getLineNumber(node.getStart()));
return true;
the printout is like:
<Variable start='8' length='5' isDollared='true'>
<Identifier start='9' length='4' name='name'/>
</Variable>
1
name
<Variable start='27' length='9' isDollared='true'>
<Identifier start='28' length='8' name='yearBorn'/>
</Variable>
1
<Variable start='46' length='12' isDollared='true'>
<Identifier start='47' length='11' name='currentYear'/>
</Variable>
1
<Variable start='67' length='4' isDollared='true'>
<Identifier start='68' length='3' name='age'/>
</Variable>
1
why it returns 1 for the line number. What is the correct way to retrieve line number?
Re: getLineNumber [message #1060084 is a reply to message #1059833] |
Wed, 22 May 2013 23:13   |
As you can see org.eclipse.php.internal.core.ast.nodes.Program.getLineNumber(int), the method needs org.eclipse.php.internal.core.ast.nodes.Program.lineEndTable and it is set by org.eclipse.php.internal.core.ast.nodes.Program.setLineEndTable(int[]) which is called from org.eclipse.php.internal.ui.editor.validation.PhpReconcilingStrategy.reconcile(ISourceModule, boolean) and org.eclipse.php.internal.ui.viewsupport.SelectionListenerWithASTManager.PartListenerGroup.calculateASTandInform(ISourceModule, ITextSelection, IProgressMonitor).
In short, Program.getLineNumber() is available on the php editor and the AST within it. It may not be available in your visitor implementation.
node must be the AST in the editor.
For example,
PHPStructuredEditor phpStructuredEditor = // get the instance somehow
IModelElement element = phpStructuredEditor.getModelElement();
if (element instanceof ISourceModule) {
try {
program = SharedASTProvider.getAST((ISourceModule) element, SharedASTProvider.WAIT_ACTIVE_ONLY, null);
} catch (ModelException | IOException e) {
I don't recommend this way because it may return unexpected(incorrect) value in a certain case.
Other way is using org.eclipse.jface.text.Document.
For example,
Document document = new Document(node.getProgramRoot().getSourceModule().getSource());
System.out.println(document.getLineOfOffset(node.getStart()) + 1);
return true;
FUDForum. Page generated in 0.04587 seconds
