Home » Newcomers » Newcomers » Can't Access Eclipse Error Message
Can't Access Eclipse Error Message [message #1060058] Wed, 22 May 2013 14:19 Go to next message
When I launch eclipse I get an error message saying "An error has occurred. See the log file C:\Users\Andrew\workspace\.metadata\.log"
I checked the log file but I don't understand it.
The log file is here:
!SESSION 2013-05-08 12:19:46.936 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.7.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.java.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2013-05-08 12:19:58.466
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle "reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.2.R36x_v20110114.jar" by thread "Start Level Event Dispatcher".
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.beginStateChange(AbstractBundle.java:1077)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:548)
	at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1097)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.suspendBundle(PackageAdminImpl.java:311)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.processDelta(PackageAdminImpl.java:457)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.doResolveBundles(PackageAdminImpl.java:239)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1.run(PackageAdminImpl.java:174)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$BundleStatusException
	... 8 more
Root exception:
!SESSION 2013-05-09 10:10:51.797 -----------------------------------------------
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.786
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
	at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:172)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
	at org.eclipse.swt.widgets.Widget.release(Widget.java:808)
	at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:872)
	at org.eclipse.swt.widgets.Widget.release(Widget.java:811)
	at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:167)
	at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:773)
	at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1267)
	at org.eclipse.swt.widgets.Widget.dispose(Widget.java:446)
	at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java:447)
	at org.eclipse.swt.widgets.Shell.dispose(Shell.java:714)
	at org.eclipse.swt.widgets.Display.release(Display.java:3707)
	at org.eclipse.swt.graphics.Device.dispose(Device.java:295)
	at org.eclipse.swt.widgets.Display.messageProc(Display.java:3188)
	at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454)
	at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:497)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4253)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1598)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2038)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4886)
	at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3024)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3652)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.java:334)
	at org.eclipse.jface.dialogs.MessageDialogWithToggle.open(MessageDialogWithToggle.java:114)
	at org.eclipse.jface.dialogs.MessageDialogWithToggle.openOkCancelConfirm(MessageDialogWithToggle.java:209)
	at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.promptOnExit(IDEWorkbenchWindowAdvisor.java:198)
	at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor$2.handleEvent(IDEWorkbenchAdvisor.java:164)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4240)
	at org.eclipse.swt.widgets.Display.messageProc(Display.java:3201)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.793
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.796
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.797
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.799
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.801
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2013-05-09 12:22:04.803
!STACK 0
!SESSION 2013-05-09 22:59:00.997 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-05-09 22:59:05.843
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!SESSION 2013-05-15 11:31:44.965 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-05-15 11:31:51.036
!SESSION 2013-05-15 11:33:03.695 -----------------------------------------------
eclipse.buildId=M20130204-1200
!ENTRY org.eclipse.equinox.p2.operations 4 0 2013-05-15 11:37:36.826
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.826
!MESSAGE Cannot complete the install because of a conflicting dependency.
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.826
!MESSAGE Software being installed: Android Native Development Tools 21.1.0.v201302060044-569685 (com.android.ide.eclipse.ndk.feature.group 21.1.0.v201302060044-569685)
!MESSAGE Software currently installed: Eclipse SDK 3.6.0.I20100608-0911 (org.eclipse.sdk.ide 3.6.0.I20100608-0911)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.826
!MESSAGE Only one of the following can be installed at once:
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.826
!MESSAGE Debug Core 3.7.100.v20120521-2012 (org.eclipse.debug.core 3.7.100.v20120521-2012)
!MESSAGE Debug Core 3.6.0.v20100519 (org.eclipse.debug.core 3.6.0.v20100519)
!MESSAGE Cannot satisfy dependency:
!MESSAGE From: Android Native Development Tools 21.1.0.v201302060044-569685 (com.android.ide.eclipse.ndk.feature.group 21.1.0.v201302060044-569685)
!MESSAGE To: org.eclipse.cdt.feature.group 0.0.0
!MESSAGE From: C/C++ Development Tools Debugger UI 7.2.0.201206111645 (org.eclipse.cdt.debug.ui 7.2.0.201206111645)
!MESSAGE To: bundle org.eclipse.debug.core [3.7.0,4.0.0)
!MESSAGE From: C/C++ Development Tools Debugger UI 7.2.0.201209170703 (org.eclipse.cdt.debug.ui 7.2.0.201209170703)
!MESSAGE From: C/C++ Development Tools Debugger UI 7.2.0.201302132326 (org.eclipse.cdt.debug.ui 7.2.0.201302132326)
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.827
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.827
!MESSAGE From: C/C++ Development Tools 8.1.0.201206111645 (org.eclipse.cdt.feature.group 8.1.0.201206111645)
!MESSAGE To: org.eclipse.cdt.platform.feature.group [8.1.0.201206111645]
!MESSAGE From: C/C++ Development Tools 8.1.1.201209170703 (org.eclipse.cdt.feature.group 8.1.1.201209170703)
!MESSAGE To: org.eclipse.cdt.platform.feature.group [8.1.1.201209170703]
!MESSAGE From: C/C++ Development Tools 8.1.2.201302132326 (org.eclipse.cdt.feature.group 8.1.2.201302132326)
!MESSAGE To: org.eclipse.cdt.platform.feature.group [8.1.2.201302132326]
!MESSAGE From: C/C++ Development Platform 8.1.0.201206111645 (org.eclipse.cdt.platform.feature.group 8.1.0.201206111645)
!MESSAGE To: org.eclipse.cdt.debug.ui [7.2.0.201206111645]
!MESSAGE From: C/C++ Development Platform 8.1.1.201209170703 (org.eclipse.cdt.platform.feature.group 8.1.1.201209170703)
!MESSAGE To: org.eclipse.cdt.debug.ui [7.2.0.201209170703]
!MESSAGE From: C/C++ Development Platform 8.1.2.201302132326 (org.eclipse.cdt.platform.feature.group 8.1.2.201302132326)
!MESSAGE To: org.eclipse.cdt.debug.ui [7.2.0.201302132326]
!MESSAGE From: Eclipse Platform 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY (org.eclipse.platform.feature.group 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
!MESSAGE To: org.eclipse.debug.core [3.6.0.v20100519]
!MESSAGE From: Eclipse Project SDK 3.6.0.v20100427-7Q7m-DPY2dP0s7TnP1vxqsprbrvrHJwHMVz0mb8mhRXmu (org.eclipse.sdk.feature.group 3.6.0.v20100427-7Q7m-DPY2dP0s7TnP1vxqsprbrvrHJwHMVz0mb8mhRXmu)
!MESSAGE To: org.eclipse.platform.feature.group [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
!MESSAGE From: Eclipse SDK 3.6.0.I20100608-0911 (org.eclipse.sdk.ide 3.6.0.I20100608-0911)
!MESSAGE To: org.eclipse.sdk.feature.group [3.6.0.v20100427-7Q7m-DPY2dP0s7TnP1vxqsprbrvrHJwHMVz0mb8mhRXmu]
!ENTRY org.eclipse.equinox.p2.operations 4 0 2013-05-15 11:37:36.833
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.833
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.833
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.833
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.833
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2013-05-15 11:37:36.834
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2013-05-15 11:37:36.834
!SESSION 2013-05-15 11:46:40.330 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-05-15 11:46:49.360
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.egit.ui 2 0 2013-05-15 11:46:49.361
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\Andrew'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
!SESSION 2013-05-15 11:47:48.246 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-05-15 11:49:58.329
!ENTRY org.eclipse.egit.ui 2 0 2013-05-15 11:49:58.330
!SESSION 2013-05-17 10:48:51.688 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-05-17 10:49:01.628
!ENTRY org.eclipse.egit.ui 2 0 2013-05-17 10:49:01.629
!ENTRY org.eclipse.m2e.logback.appender 4 0 2013-05-17 11:02:22.313
!MESSAGE Failed to open search index.
!SESSION 2013-05-20 12:00:09.525 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-05-20 12:00:19.202
!ENTRY org.eclipse.egit.ui 2 0 2013-05-20 12:00:19.203
!SESSION 2013-05-20 18:16:11.464 -----------------------------------------------
!ENTRY org.eclipse.egit.ui 2 0 2013-05-20 18:16:22.769
Re: Can't Access Eclipse Error Message [message #1060118 is a reply to message #1060058] Thu, 23 May 2013 03:50 Go to previous message
You have messages from two different Eclipse versions mixed together. Pick which version you're sticking with and then indicate which message you're stuck on.
[Updated on: Thu, 23 May 2013 03:50] by Moderator
Previous Topic:External Tools Input
Next Topic:Eclipse resources
Current Time: Sun Jul 27 08:13:17 EDT 2025
Powered by FUDForum. Page generated in 0.08467 seconds
