Home » Modeling » GMF (Graphical Modeling Framework) » Qualified names on referance labels
Qualified names on referance labels [message #1053673] Tue, 07 May 2013 04:29 Go to next message
Hi all,
I need qualified name on reference labels but don't know how can i implement this
feature anyone can help me to do ?
Sample scenario is on attached picture
regards.
Re: Qualified names on referance labels [message #1053751 is a reply to message #1053673] Tue, 07 May 2013 09:42 Go to previous messageGo to next message
did you try the expression labels in GMF. You can define OCL expressions to calculate the text which is displayed in the label.
Ralph
Re: Qualified names on referance labels [message #1053756 is a reply to message #1053751] Tue, 07 May 2013 09:57 Go to previous messageGo to next message
No i dont try this. Because i am so new to gmf and dont know how can i do this. Can u
explain me this approach ?
[Updated on: Wed, 08 May 2013 09:57] by Moderator
Re: Qualified names on referance labels [message #1058218 is a reply to message #1053756] Mon, 13 May 2013 05:14 Go to previous messageGo to next message
it is quite easy go to to your gmfmap file. Instead of adding a feature label you can add an expression label. To this expression label you can add ocl expressions computing the value of the label.
Ralph
Re: Qualified names on referance labels [message #1058523 is a reply to message #1058218] Tue, 14 May 2013 07:56 Go to previous messageGo to next message
Yes i try and labels on diagram look like qualified name but i must do this for
properties section too. so i must do this same way ?
Re: Qualified names on referance labels [message #1058987 is a reply to message #1058523] Thu, 16 May 2013 02:58 Go to previous messageGo to next message
What do you want in the properties section? Derive a semantic attribute of the model? You could do this by using EMF and OCL.
Re: Qualified names on referance labels [message #1059101 is a reply to message #1058987] Thu, 16 May 2013 13:20 Go to previous messageGo to next message
i cant do this it works only labels i think. But i need to show instances name as
qualified name on properties section of diagram. So i try another way, i change
the emf model getXXX(); method but when this method activated my element names change
too because when i save my diagram, Diagram thinks I changed the name of the model
instance. So if i can do this with expression label way, i think it works same as
another way too.
(on attached image u can see properties section. Its in the lower left of picture)
Re: Qualified names on referance labels [message #1059425 is a reply to message #1059101] Sat, 18 May 2013 04:59 Go to previous messageGo to next message
where in the properties view do you want to show the fully qualified name? In the heading of it or in the table section? If you want to have it in the heading you can modify xxxSheetLabelProvider's getText() method.
Ralph
Re: Qualified names on referance labels [message #1059505 is a reply to message #1059425] Mon, 20 May 2013 02:21 Go to previous messageGo to next message
(on attached picture i explain where i need to qualified name.)
When i write this code to ContentSheetLabelProvider;
public String getText(Object element) {
		element = unwrap(element);
		if (element instanceof ContentNavigatorGroup) {
			return ((ContentNavigatorGroup) element).getGroupName() + ".serhat";
		IElementType etype = getElementType(getView(element));
		return etype == null ? "" : etype.getDisplayName() + ".serhat";
I get attached picture. But i need changed name on 2. section (on Attache picture you can see 2. section)
regards
  • Attachment: aaaa.png
    (Size: 188.24KB, Downloaded 189 times)
[Updated on: Mon, 20 May 2013 02:22] by Moderator
Re: Qualified names on referance labels [message #1060008 is a reply to message #1059505] Wed, 22 May 2013 10:16 Go to previous messageGo to next message
Have no one did need this feature?
Re: Qualified names on referance labels [message #1060342 is a reply to message #1060008] Fri, 24 May 2013 04:35 Go to previous messageGo to next message
you should be able to change the presentation here by modifying you generated .edit code provided by gmf. You should take a look at this http://wiki.eclipse.org/EMF/Recipes#Recipe:_Custom_Labels .
Ralph
Re: Qualified names on referance labels [message #1060377 is a reply to message #1060342] Fri, 24 May 2013 07:09 Go to previous messageGo to next message
Yes this is the solution of my problem thanks
Re: Qualified names on referance labels [message #1061333 is a reply to message #1060377] Fri, 31 May 2013 05:14 Go to previous messageGo to next message
you could think of overwriting EMF's Jet Templates in case that you delete your generated code in future. This could save you some work then.
Ralph
Re: Qualified names on referance labels [message #1061812 is a reply to message #1061333] Tue, 04 June 2013 04:20 Go to previous message
Thats look good i'll try
Previous Topic:Where are NLS messages defined?
Next Topic:Property Selection Filter on Property Section
Current Time: Wed Jul 23 16:57:45 EDT 2025
Powered by FUDForum. Page generated in 0.28185 seconds
