Home » Language IDEs » PHP Development Tools (PDT) » getLineNumber
getLineNumber [message #1059833] Tue, 21 May 2013 15:30 Go to next message
I am using the org.eclipse.php.internal.core for parsing PHP code. Here is a small test php file to pars:
<?php
$name = 'Elijah';
$yearBorn = 1975;
$currentYear = 2005;
$age = $currentYear - $yearBorn;
To get the line number I do as following
public class FactExtractorVisitor implements Visitor {
public boolean visit(Program node) {
	// TODO Auto-generated method stub
	this.root=node;
	return true;
public boolean visit(Variable node) {
    System.out.println(node.toString());
    System.out.println(this.root.getLineNumber(node.getStart()));
    return true;
the printout is like:
<Variable start='8' length='5' isDollared='true'>
<Identifier start='9' length='4' name='name'/>
</Variable>
1
name
<Variable start='27' length='9' isDollared='true'>
<Identifier start='28' length='8' name='yearBorn'/>
</Variable>
1
<Variable start='46' length='12' isDollared='true'>
<Identifier start='47' length='11' name='currentYear'/>
</Variable>
1
<Variable start='67' length='4' isDollared='true'>
<Identifier start='68' length='3' name='age'/>
</Variable>
1
why it returns 1 for the line number. What is the correct way to retrieve line number?
Re: getLineNumber [message #1060084 is a reply to message #1059833] Wed, 22 May 2013 23:13 Go to previous messageGo to next message
As you can see org.eclipse.php.internal.core.ast.nodes.Program.getLineNumber(int), the method needs org.eclipse.php.internal.core.ast.nodes.Program.lineEndTable and it is set by org.eclipse.php.internal.core.ast.nodes.Program.setLineEndTable(int[]) which is called from org.eclipse.php.internal.ui.editor.validation.PhpReconcilingStrategy.reconcile(ISourceModule, boolean) and org.eclipse.php.internal.ui.viewsupport.SelectionListenerWithASTManager.PartListenerGroup.calculateASTandInform(ISourceModule, ITextSelection, IProgressMonitor).
In short, Program.getLineNumber() is available on the php editor and the AST within it. It may not be available in your visitor implementation.
node must be the AST in the editor.
For example,
PHPStructuredEditor phpStructuredEditor = // get the instance somehow
IModelElement element = phpStructuredEditor.getModelElement();
if (element instanceof ISourceModule) {
    try {
        program = SharedASTProvider.getAST((ISourceModule) element, SharedASTProvider.WAIT_ACTIVE_ONLY, null);
    } catch (ModelException | IOException e) {
I don't recommend this way because it may return unexpected(incorrect) value in a certain case.
Other way is using org.eclipse.jface.text.Document.
For example,
    Document document = new Document(node.getProgramRoot().getSourceModule().getSource());
    System.out.println(document.getLineOfOffset(node.getStart()) + 1);
    return true;
Re: getLineNumber [message #1060267 is a reply to message #1060084] Thu, 23 May 2013 13:59 Go to previous messageGo to next message
Thank you very much for replying,
When I use the org.eclipse.jface.text.Document in "org.eclipse.text.jar" I get the following exception. I did add the "org.eclipse.text.jar"to the classpath that is under the runtime tab of the MANIFEST.MF.
When running on command line I specify this jar through -cp.
I do'not have any compile errors and when clinking on type Document in my visitor class, the declaration of class Document is opened so I don't know why I get this exception:
!SESSION 2013-05-23 12:53:14.842 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.7.0_10-ea
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -application phpparser.parser.Runner TestPHPExamples
Command-line arguments: -application phpparser.parser.Runner TestPHPExamples
!ENTRY org.eclipse.osgi 4 0 2013-05-23 12:53:16.527
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/jface/text/Document
at phpparser.parser.visitors.FactExtractorVisitor.visit(FactExtractorVisitor.java:1033)
at org.eclipse.php.internal.core.ast.nodes.Variable.accept0(Variable.java:112)
at org.eclipse.php.internal.core.ast.nodes.ASTNode.accept(ASTNode.java:290)
at org.eclipse.php.internal.core.ast.nodes.GlobalStatement.childrenAccept(GlobalStatement.java:80)
at org.eclipse.php.internal.core.ast.nodes.GlobalStatement.accept0(GlobalStatement.java:73)
at org.eclipse.php.internal.core.ast.nodes.Program.childrenAccept(Program.java:195)
at org.eclipse.php.internal.core.ast.nodes.Program.accept0(Program.java:188)
at phpparser.parser.Parser.parseFile(Parser.java:101)
at phpparser.parser.Parser.parseScriptProject(Parser.java:75)
at phpparser.parser.Parser.parseProject(Parser.java:32)
at phpparser.parser.Runner.run(Runner.java:13)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.text.Document
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
... 31 more
Any suggestion?
Re: getLineNumber [message #1060471 is a reply to message #1060267] Fri, 24 May 2013 20:24 Go to previous messageGo to next message
Why.
Add 'org.eclipse.jface.text' to 'Dependencies'.
Re: getLineNumber [message #1060675 is a reply to message #1060471] Mon, 27 May 2013 12:11 Go to previous message
THANKS A LOT Razz
Previous Topic:Linking eclipse simulator and FORTRAN language
Next Topic:Projects missing on Samba share on Eclipse launch
Current Time: Sun Jul 27 09:19:26 EDT 2025
Powered by FUDForum. Page generated in 0.04826 seconds
