Home » Language IDEs » C / C++ IDE (CDT) » Can't configure Indexer to recognize "forced-included" files (/fi parameter)
Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1059622] Mon, 20 May 2013 17:06 Go to next message
Hi all,
I am using Eclipse Indigo with Visual Studio 2012, and the code I am working on creates a header file (with tons of macro denifitions) that is included into every other file by using the force include parameter (/FI).
I was able to successfully configure the build parameters, by adding the parameter "/FI<filename.h>" on Project Properties->C/C++ Build->Settings->C Compiler (cl)->Miscellaneous.
But it seems the Indexer can't find the macros on the (previously) automatically created file. As a result, Eclipse shows tons of syntax error and non resolved types/symbols, but I am able to build the executable.
So, I was wondering if there is any way to specify this include so the Indexer recognizes the macros on it.
Thanks in advance,
UPDATE:
I am actually using Eclipse Juno, but tried also with Indigo.
[Updated on: Tue, 21 May 2013 10:53] by Moderator
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1059907 is a reply to message #1059622] Wed, 22 May 2013 03:17 Go to previous messageGo to next message
1) Open Windows->Preferences and go to C/C++->Property Pages Settings
2) Enable "Display Include Files on Paths and Symbols page
3) Open project properties and got to C/C++ General->Paths and Symbols
4) select tab Include Files
5) click Add button to add your header file filename.h (depending on your language you must add it for C and C++)
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1060006 is a reply to message #1059907] Wed, 22 May 2013 10:09 Go to previous messageGo to next message
Hi Axel,
First, thank you for your help.
But I couldn't find the "Include Files" tab you mentioned, either on Indigo or Juno.
As you can see on these screenshots:
index.php/fa/15013/0/
index.php/fa/15014/0/
Is there anything else I can do to enable it?
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1060143 is a reply to message #1060006] Thu, 23 May 2013 05:50 Go to previous messageGo to next message
That's strange. It works for me on Juno. Did you try to close/reopen the project, restart Eclipse?
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1061009 is a reply to message #1060143] Wed, 29 May 2013 09:44 Go to previous messageGo to next message
Try "Preprocessor Include Paths..." property page. Select your language and "CDT User Setting Entries" provider. Hit "Add", there is a dropbox initially showing "Include Directory". Select "Include File" instead.
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1061017 is a reply to message #1061009] Wed, 29 May 2013 10:12 Go to previous messageGo to next message
Thank you Andrew,
That seems to do the trick.
Another different, but related, question: is there any way to tell Eclipse (or its Indexer) to not consider system libraries (/X cl.exe parameter)?
I could find it for the GCC-based toolchains, but for the MSVC toolchain I couldn't.
Thanks again.
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1444878 is a reply to message #1061009] Tue, 14 October 2014 13:40 Go to previous messageGo to next message
Andrew Gvozdev wrote on Wed, 29 May 2013 13:44
The problem is this won't be stored inside the project settings. It will be stored in the workspace metadata: .metadata\.plugins\org.eclipse.cdt.core. Is there any chance to set forced include files in the toolchain settings in .cproject? Eclipse is so frustrating.
Re: Can't configure Indexer to recognize "forced-included" files (/fi parameter) [message #1444933 is a reply to message #1444878] Tue, 14 October 2014 15:44 Go to previous message
Ok, I figured this out. It is in .cproject in <option id="gnu.cpp.compiler.option.include.files.517432834" name="Include files (-include)" superClass="gnu.cpp.compiler.option.include.files" valueType="includeFiles">.
Previous Topic:Default build behaviour when Cygwin is in PATH
Next Topic:Unable to get Kepler working with c++11
Current Time: Sun Aug 31 12:09:12 EDT 2025
Powered by FUDForum. Page generated in 0.05049 seconds
