Home » Eclipse Projects » Eclipse Scout » Swing: Default-Field Height to small?
Swing: Default-Field Height to small? [message #1053345] Sat, 04 May 2013 04:14 Go to next message
It looks like the default text field height is too small. See the picture. The letters with decender height (j,g,..) have not enough space.
index.php/fa/14636/0/
It there a way to change the default height setting?
BW,
Volkert
Eclipse Juno SR2 / Scout 3.8.2
Windows 7 SP1
Java 1.7.0_21
[Updated on: Thu, 09 May 2013 01:08] by Moderator
Re: Swing: Default-Field Height to small? [message #1053432 is a reply to message #1053345] Sun, 05 May 2013 11:41 Go to previous messageGo to next message
You use the default Nimbus Swing look and feel?
I remember there is a property or a configuration you can set somewhere... I will try to find it.
Re: Swing: Default-Field Height to small? [message #1053453 is a reply to message #1053432] Mon, 06 May 2013 00:14 Go to previous messageGo to next message
Jeremie Bresson wrote on Sun, 05 May 2013 17:41
Yes ...
Re: Swing: Default-Field Height to small? [message #1053592 is a reply to message #1053453] Mon, 06 May 2013 12:08 Go to previous messageGo to next message
You can control the height of the fields in a scout form by overriding a method in your swing environment:
<your app>.ui.swing.SwingEnvironment:
public class SwingEnvironment extends org.eclipse.scout.rt.ui.swing.DefaultSwingEnvironment {
  public int getFormRowHeight() {
    return 40;
index.php/fa/14667/0/
For other properties (font...) you can take control of the LookAndFeel properties (have a look at javax.swing.plaf.basic.BasicLookAndFeel in the Swing code).
Re: Swing: Default-Field Height to small? [message #1057824 is a reply to message #1053592] Thu, 09 May 2013 01:06 Go to previous messageGo to next message
Thanks.
Is it now possible to have a vertical centered label (aligned to the center of text field)?
index.php/fa/14711/0/
  • Attachment: center.PNG
    (Size: 1.97KB, Downloaded 673 times)
[Updated on: Thu, 09 May 2013 01:07] by Moderator
Re: Swing: Default-Field Height to small? [message #1059591 is a reply to message #1057824] Mon, 20 May 2013 12:01 Go to previous message
I did not forget you, but it seems to be complicated (I do not know Swing well).
So far, I had a look at:
org.eclipse.scout.rt.ui.swing.AbstractSwingEnvironment.createStatusLabel(IFormField)
I did not manage to understand if the JLabel contained in the JPanel labelPanel of the StatusLabelEx has the correct size or not. Maybe a call like this is missing (in the Constructor of JStatusLabelEx()):
m_label.setVerticalTextPosition(SwingConstants.CENTER)
I will try to figure it out.
Previous Topic:Renaming Services
Next Topic:Eclipse Scout on OS X Java 7
Current Time: Sun Jul 27 07:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.04671 seconds
