Home » Eclipse Projects » EclipseLink » What is happening here
What is happening here [message #1059015] Thu, 16 May 2013 04:35 Go to next message
Dear Friends ,
I beg your pardon , if anybody knows what is the problem with my design.
the problem is for just a simple select statement to select 8 referral requests , it takes too much time to view them , i have turned the logging feature of eclipselink on to see what is really going on , i saw a huge logging lines appear for just simple retrieve of the referral requests .
i have attached my entities , screenshot of the page that views the retrieved requests and the logging output from eclipselink during running the system on my local host, i am using glassfish 3.1.1 , Spring 3.0 , primefaces and eclipselink as a persistence provider.
  • Attachment: logging.zip
    (Size: 218.55KB, Downloaded 219 times)
  • Attachment: screenshot.png
    (Size: 256.80KB, Downloaded 212 times)
Re: What is happening here [message #1059061 is a reply to message #1059015] Thu, 16 May 2013 09:29 Go to previous messageGo to next message
The log is too big and you have too many classes to understand what to look for. Can you show what you are doing that causes you issues, and the exact SQL that it generates?
Re: What is happening here [message #1059430 is a reply to message #1059061] Sat, 18 May 2013 06:13 Go to previous messageGo to next message
The problem is as follows , i have an object graph beginning with ReferralRequestEO that has a patient object , List of ReferralSpecialtyEO , Each ReferralSpecialtyEO has a workflowTransition "Active Transition" and history transitions "History of other workflowTransitions" , Now the problem is as follows .
When you select for example 10 requests , the DataTable not only views ReferralRequest details but also some information about the patient itself that is associated with the request. when the DataTable is about to render , for each referralRequest , there is a separate Query that is issued to get the patient just to view his/her information on the data table .
I did not have pagination on the dataTable , I was selecting the entire requests that are already existing in the DB that have specific Criteria , so if you have 400 Requests , you have 400 * 2 = 800 Individual queries to retrieve the results .
Now the glassfish has specific limited HTTP Grizzely Threads associated with it , When you have multiple simultaneous users accessing the system , you end up eating all grizzely threads on the glassfish and become unresponsive .
I think this is N+1 Problem that i am facing.
If you can help me by looking at my Entities Design and see if there is any single recommendation for me to do , i will appreciate that from you .
Thank you in advance.
Yours;
Mohamed Ibrahim
Re: What is happening here [message #1060030 is a reply to message #1059430] Wed, 22 May 2013 11:02 Go to previous message
See,
http://java-persistence-performance.blogspot.com/2010/08/batch-fetching-optimizing-object-graph.html
Previous Topic:Retry on closed Connection
Next Topic:TabelDefinition for JPAEntity.class
Current Time: Tue Jul 22 23:00:27 EDT 2025
Powered by FUDForum. Page generated in 0.04302 seconds
