Home » Modeling » EMF » Xcore and contains of referenced model(Xcore)
Xcore and contains of referenced model [message #1059346] Fri, 17 May 2013 11:17 Go to next message
How can I model a containment like this with a class from a referenced model?
import a.b.c.Y
class X {
contains Y y
Where Y is defined in another model which is just on the classpath.
I can do this:
class X {
contains Y y
class Y {}
But not when Y is in a referenced model.
Re: Xcore and contains of referenced model [message #1059351 is a reply to message #1059346] Fri, 17 May 2013 11:32 Go to previous messageGo to next message
Udo,
If Y is on the classpath (presumably in another project with an Xtext
nature) as soon as you hit Ctrl-Space (marked ^ below) it should show
you all the GenClasses visible on the classpath that start with Y and
should produce the correct import for you.
class X {
contains Y^
What does name completion show you after the "contains" keyword? Are you
using a recent build?
> model?
> import a.b.c.Y
> class X {
> contains Y y
> I can do this:
> class X {
> contains Y y
> class Y {}
Re: Xcore and contains of referenced model [message #1059354 is a reply to message #1059351] Fri, 17 May 2013 11:41 Go to previous messageGo to next message
Hmm, the other project is not an Xtext project. It is an EMF project where I created interfaces with Javadoc annotations and then used the genmodel tools to create a genmodel file from the interfaces and an ecore file with the generator in the genmodel editor.
I put that project on the plug-in classpath of the xcore project.
If I try to use Ctrl-Space the I do get nothing to choose from.
I did myself an import of the referenced "interface" but then I have to create a type wrapper which I cannot use with the "contains" keyword.
Should I use som genmodel annotations to fix my classpath or is it a missing feature to mix "old" EMF projects with xcore?
Re: Xcore and contains of referenced model [message #1059362 is a reply to message #1059354] Fri, 17 May 2013 12:26 Go to previous messageGo to next message
Udo,
Comments below.
I'm pretty sure that Xtext will index workspace projects only when they
have an Xtext nature, so you'd need to that nature with "Configure ->
Add Xtext Nature" from the context menu on that project.
No, you really need access to the other models GenModel for this to work
properly.
No, adding the Xtext nature to that other project should be sufficient
to get Xtext to index it and make the stuff from the contained GenModels
available to other Xcore models.
Re: Xcore and contains of referenced model [message #1059415 is a reply to message #1059362] Sat, 18 May 2013 02:03 Go to previous messageGo to next message
That means I cannot use a binary dependency?
Re: Xcore and contains of referenced model [message #1059417 is a reply to message #1059415] Sat, 18 May 2013 02:15 Go to previous message
Udo,
No, a binary dependency (in the target platform) should be indexed
automatically.
Previous Topic:[CDO] revisions or versions list.
Next Topic:Help with Transactional Editing Domain and Modal Dialogs
Current Time: Sat Jul 26 20:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
