Home » Modeling » M2T (model-to-text transformation) » Properties of ecore classes
Properties of ecore classes [message #1059212] Fri, 17 May 2013 06:42 Go to next message
Hi modelers ,
I am beginner in modeling and modeling transformation ,Working with ecore.ecore trying to do some transformation using xpand language ,I could naviagte and access elements of ecore using eclass , eallattributes , eallreferences ,ealloperations ....etc Syntax ,the question is when I click on any eclass , I have some properties that are not part of the structure of eclass , like abstract , default value , supertype ....etc attached picture to show what I mean, is there any code in xpand can enumerate these properties so I can keep all information in the transformation process.
Thanks in advance.
  • Attachment: Unbenannt.png
    (Size: 160.20KB, Downloaded 202 times)
[Updated on: Fri, 17 May 2013 06:43] by Moderator
Re: Properties of ecore classes [message #1059250 is a reply to message #1059212] Fri, 17 May 2013 07:04 Go to previous messageGo to next message
You need to look a little harder. Everything you list is part of the
structure of an EClass. What makes you think it isn't?
Ed Willink
On 17/05/2013 11:42, Adnan AL-SOSWA wrote:
> Hi modlers ,
> Thanks in advance.
Re: Properties of ecore classes [message #1059312 is a reply to message #1059250] Fri, 17 May 2013 09:35 Go to previous message
Thanks ED,
Actually what make me think like this is that when I tried to get all attributes of eclass for example using eallattribute , I got all the attributes of the eclass and attributes of all of its super types ,but non of these properties are included .
if they are not attributes what they are actually are in the structure ?
could you please guide me where exactly i should look a little harder Smile as I read the whole specification of EMF ?
Thank you very much
Previous Topic:[Acceleo] NullPointerException during Tycho Build
Next Topic:[Acceleo] MDD/MDE conferences
Current Time: Fri Jul 25 06:58:43 EDT 2025
Powered by FUDForum. Page generated in 0.04947 seconds
